Old 04-09-2003, 03:54 PM
BillyP
3.29:1 gear set mod!
I did this mod because I liked my Mario Kart wheels, but I
didn't want to be stuck with a 9.86:1 gear ratio in order to
use them.
Old 04-09-2003, 03:56 PM
BillyP
I connected the two pinion gears with a bit racer gear, because the white pinion gears are designed to mesh with bit racer gears. The dual motors should have more than enough torque to handle this. The white pinion gear is exactly the same as the inner gear that turns the wheels in the orange set!
Old 04-09-2003, 09:44 PM
dr1zz's Avatar
dr1zz dr1zz is offline
phear meh..............
i dont get it?!?
wouldnt that be just like running off one motor (the front one). i never understood the dual motor idea.
some clones have that goofy rim design as the mario and yoshi. i think cannonballs.
Old 04-10-2003, 03:39 PM
xatu's Avatar
xatu xatu is offline
they say im slooooow eh?
Nice job! But, uh, I don't get how it runs... there is the two motors, I get that, but why is there a idler gear on top of them?
[edit]
Nevermind, I get it. The motor on the end would not touch the drive gear, so.... You put that gear in there as an idler gear, and so it is all in a chain like sort of thing... I'll try to draw a diagram:
....O < this is the idler gear
..O..O < these two on this line are the motors
O < this is the wheel and the gear
Am I right?
Old 04-10-2003, 03:55 PM
BillyP
Explanation.
The back motor does not touch the drive gear. The front motor can work alone, as it would if I removed the idler gear.
The car would stall like crazy with only one motor, because it would not have enough torque for such a low gear ratio.
Yes, xatu, you're right. You just edited your post while I was typing this!
Custom Crawler Gear Mod hartoy53 ZipZaps Monster Truck 3 06-30-2008 02:44 AM
4th gear mod help hothotheat ZipZaps Monster Truck 3 03-28-2006 10:25 PM
shaft mod with belt xfer vs. gear xfer? cdog4w Mini-X Parts and Hop-Ups 3 03-12-2004 12:54 PM
need ZZ purple motor and red gear set rt450 For Sale/Trade 18 12-09-2003 03:02 PM
Question about fullsize wheels set Mod..? SPEED QFM Racing Customer Support 5 09-25-2002 11:26 AM
