Old 01-15-2003, 09:06 PM
arceeguy
20Mhz Bit modification
So, you sick of having frequency conflicts with your buddies? Easy fix, mod your car to run on a frequency nobody else has! It's pretty simple to do, but you'll need some soldering skills. Here is the procedure:
1: Buy a 20Mhz crystal. They are less than a buck from DigiKey.com. I got mine from a junk 386 computer motherboard. (20 Mhz processor )
2: I replaced the 27.xxxMhz crystal in the Tx with the 20Mhz crystal.
3: Re-tune the Bit PCB for maximum range on the new frequency. This is probably the hardest part because I had to melt the wax out of the tuning coil to get the tuning tool in to turn the ferrite slug in the coil. You MUST use a plastic tool, I got mine from a local electronics store - Radio Shaft may carry them too.
You don't need to tune the transmitter because it doesn't have a LC circuit on the output stage.
Other frequencies are possible, but if you stray too far away from the cars original frequency, you'll have to modify/replace the tuning coil and/or the capacitor across the coil to re-tune the circuit.
The mod didn't increase the range any, but then again - it didn't hurt the range either! I get about 12ft. before it starts to stutter. The test mule is a LXX clone.
Old 01-16-2003, 06:32 PM
t-squared's Avatar
t-squared t-squared is offline
Bit Obessed...
would the 20mhz screw up a 27mhz car?
Old 01-16-2003, 06:40 PM
arceeguy
I've had no problems with interference. The 7Mhz spacing is adequate to prevent interference. If you put the Tx antenna right next to a 27 or 35Mhz car it will control it, but the same is true with the "regular" frequencies.
Factoid: did you know that 57Mhz in in our TV frequency band here in the US? (VHF "Lo")
Old 01-16-2003, 10:09 PM
DarthRacer's Avatar
DarthRacer DarthRacer is offline
Sith Bit Racer
Send a message via AIM to DarthRacer
Did you also know that TV channels are 6Mhz apart?
- Calsonic
Old 03-10-2003, 06:47 PM
BigPappaBuck BigPappaBuck is offline
Has anybody else did this with their cars?
I was thinking of making a 40 mhz car out of a 45 mhz car.
Old 03-12-2003, 04:42 PM
strider_mt2k
Very clever idea!
This should be in Bit Science I think.
Old 03-12-2003, 06:07 PM
sm2osley's Avatar
sm2osley sm2osley is offline
.002 sec away from $100!!
what does Tx mean
2 Busses (1 Disney Resort Cruiser)
1 Speed Racer
1 Monster Truck
Body kitted celica
Old 03-12-2003, 07:16 PM
Squishy's Avatar
Squishy Squishy is offline
Quack
The transmiter (controller), I believe.
Old 03-12-2003, 07:38 PM
arceeguy
I haven't tried a 40Mhz custom yet, but the 20Mhz car is still running fine. It really does come in handy when a bunch of people get together. I can always use my favorite car. Isn't 40Mhz a "legal" frequency in Australia? Anyway, re-tuning a 45Mhz Bit probably wouldn't be a problem.
Old 03-13-2003, 02:10 PM
BillyP
I found 20MHz crystals at All Electronics with 20MHz resonators. Can you use a resonator in the car to change it's frequency?
Old 03-13-2003, 02:21 PM
arceeguy
I don't think a ceramic resonator will work.
You'll need a "real" quartz crystal for the type of oscillator that is in a Bit transmitter. The crystals are cheap enough anyway.
Bit Char-G: FAQs (Updated: Jan 6th, '03) Namuna Bit Char-G / MicroSizers 15 08-14-2003 10:04 PM
Bit tires vs Microsizers tires Dys70pia Bit Char-G Parts and Hop-Ups 3 12-28-2002 03:34 AM
Entire Bit collection for Sale (Customized Bits) bitfreak Bit Char-G / MicroSizers 10 09-13-2002 07:28 PM
