03-12-2003, 01:54 PM
help with my duel cells
ok i jus got my two cell 160nimh
they go quite fast but ive seen some peoples cars and they jus look great and they go soooo fast.
i try to charge them with this charger i made from a broken controller
but i am wondering if anyone know about that mod for your controller to make it charge non stop but can u still control your car with it.
please reply.
and what ways do u charge your duel cell cars
03-12-2003, 02:15 PM
i use the 4aa charger that came with my boat.
you can also ad a 3rd battery to the controller but that takes longer to charge and will eat your batteries. but that will also double your range.
you need at least 3.4v to charge dual batts. my friend tested this on a scientific grade multimeter.
i like having a stand alone charger. but i dont have range issues either or i might change my mind.
03-12-2003, 02:54 PM
Microman to the rescue!!!
I think www.questformadness.com has a mod that you do to the controller to charge multiple cells.
03-12-2003, 02:58 PM
i cant see how that would work since fresh aa's dont give off enough voltage.
03-12-2003, 04:39 PM
i am po
Micro man, thats a good mod controller on qfm, but it only works for 2.4V charges...and if freakanoid has 3.4....then it wont charge properly...right?
03-12-2003, 04:41 PM
no you need 3.4v in the charger to charge two 1.2v cells.
03-12-2003, 04:44 PM
Im not sure i just saw the mod a while back and posted lol.
03-12-2003, 05:09 PM
my friend explained this to me mathematically yesteday but the math stuff ends up sounding like "blah blah waah wah" after a few mins but pretty much batteries or any electrical component has an internal resistance. you need (im pretty sure his meter said 3.4 it may have been 3.2) volts to overcome the internal resistance before it starts charging.
one advantage to this higher internal resistance is your car wont drain as quickly if you set it down for a few hours.
03-12-2003, 05:12 PM
XMOD AUDI TT (my wish)
is it bad to charge a stock battery with 3.7 volts? i could charge a duall with it too, but does it damage the 1 cell bit?
03-12-2003, 05:14 PM
no just watch it. obviously a single cell will fill first and start getting hot first. if it does it should take off all its clothes.
heat = your battery is charged
heat = melted stuff or fire
03-12-2003, 05:17 PM
okok, so it wont damage the batt unless i keep it on for too long,
03-13-2003, 11:30 AM
ok kool
im jus gonna go buy pack like u have hogjowltz
03-13-2003, 11:34 AM
kennshop has the boats. which are worth 17bucks anyhow
03-14-2003, 12:37 PM
State Property
...everyone here should listen to GODjowlz the name says it all..
