Old 11-02-2002, 08:01 PM
catman25 catman25 is offline
tips on how to stop bit from spinning
using 2 bits one with a 3.8 one with a 2.6 ..how the hell do you get them from not spinning round??used diff..tires..would springs instead of stab work ???any tips please let me knownthanks
Old 11-02-2002, 09:31 PM
en20 en20 is offline
Arrow
Hey I go tthe same problem with my bits...I'm not sure how to fix it either...but if you drive your bits on more rough surfaces it won't spin out as much...But Im not sure how to fix this
Old 11-03-2002, 12:44 AM
tifosi_ms1 tifosi_ms1 is offline
Softer rear tires or Softer front end strut bar.
Bit Char G, Blue Skyline GT-R, 2.6 KIT
Microsizer, WRX won microsizers.com
Micro Q, F360 Modena, Working on it
Castrol Supra Body, Mobil Nsx Body
Old 11-03-2002, 12:51 AM
E)(pul$ioN E)(pul$ioN is offline
Founder of EaT RiCe Squad
Send a message via AIM to E)(pul$ioN
Yeah the Tomy Bit Char-g Color Tire Set GS-07 really makes a huge difference. Plently of GS-07 at eBay:
http://search.ebay.com/search/search...rt&query=GS-07
Old 11-03-2002, 09:08 PM
cowfish_29's Avatar
yellow fish forever!
yep, with a 3.8 on a smooth surface, its most likey gonna spin out and do donuts whatever you do, regardless of the tires. Thats the price you pay for speed. With faster motors, gathering speed THEN turning instead of turning and accelerating at the same time reduces donut-ness. And yes, using rougher surfaces like unfinished plywood and stuff like that help a lot.
Old 11-04-2002, 01:30 AM
togunter
dont have a 3.8(yet), but i find that it helps to clean my tires regularly. they seem to pick up dirt pretty quickly(might make more sense to clean the floor, but theres no time for that, only racing...).
the color tires are really nice. the soft red tires on the back with the blue hard tires on the front works great on hardwood floors.
Old 11-04-2002, 01:40 AM
delmonk delmonk is offline
To keep the car from spinning, use the softest tires on the back for superior grip to prevent the car from burnouts and fishtails. If the engine has too much torque or the car is going to fast, induce understeer by using harder tires on front. This will prevent the car from spinning and reduce chances of flipping when turning at high speed. With the 2nd hardest tires from the bit racer tire set on my front tires of my dual turbo car, my car doesnt turn as much, but its enough to prevent spins and flips. Only when I use boost does it flip, so I save the boost for straightaways.
(Racing) Silver Supra with 2.6 engine, (Racing) Yellow FD3S witn 2.6 engine, Red Evo VII with ultimate light kit, (Drag) Blue R34 with 3.8 engine, (Rally) Twin turbo Yellow Toyota bB
Old 11-04-2002, 01:44 AM
NorCalCoug's Avatar
NorCalCoug NorCalCoug is offline
l33t camber wizard :)
Best way to avoid spinouts? Lay off the throttle on a turn! Take your finger off the gas a little before the turn, make the turn, and back on the gas! You'll have enough momentum to carry you through the turn.
Old 11-04-2002, 09:27 AM
DarthRacer's Avatar
DarthRacer DarthRacer is offline
Sith Bit Racer
Send a message via AIM to DarthRacer
Funny that you bring up momentum. My MS dosen't seem to coast at all when I lay off the throttle. Should I be expecting some length of coasting distance? I need to keep on the throttle all the time or I won't make it through the turn.
Old 11-04-2002, 10:15 PM
cowfish_29's Avatar
depends, with faster motors (2.6 and up) you should be able to coast a couple of inches, to a couple of feet. If your gears bind more than they should (i.e. car screetches to a halt once you lay off the accelerator) try some different motor positions, or try that one QFM mod with the micro screws positioning the motor so it does not bind.
Once you can coast a little, this might work-
accelerate into the turn, and a bout 1/2 way to 3/4 the way through, let go and turn till the car makes it all the way facing the upcoming straightaway in the track. Then, accelerate straight down it, not turning again till you reach near top speed (as to not spin out)
This is what i do on my hardwood floors, but on other surfaces like foam core board and grippy stuff it does not seem to matter much at all. Just try it till you get what you want.
Old 11-04-2002, 11:29 PM
henry's Avatar
henry henry is offline
13B REW
i use soft tires and it dont spin wit my 3.4 but, it makes wide turns which i think is wrost. is this normal?
Old 11-05-2002, 08:25 AM
cowfish_29's Avatar
well...if you want sharper turns, put harder in the back and slightly softer in the front. I can't imagine why you would need to do this though.. my car rolls over if i use a 3.0 and soft char-g tires on back and front. Whatever works though.
Old 11-05-2002, 04:17 PM
rrvbl rrvbl is offline
If you can't get the colored tires, or want a soft black tires that are cheap, buy the Zip Zap tire / hubcap set for $4.99 at Radio Shack. All the tires are softer than the stock tires and they're all black with different tread designs. They only fit the rear wheels of the bits, but I've tried all the different treads and left the fronts with the stock tires. The result, much improved traction.
where can i buy spinning rims for my bit? NOS man Bit Char-G / MicroSizers 1 07-24-2003 05:08 PM
Entire Bit collection for Sale (Customized Bits) bitfreak Bit Char-G / MicroSizers 10 09-13-2002 07:28 PM
