Old 01-30-2003, 03:32 PM
rasolfg rasolfg is offline
Tank Takes ID but will NOT move - HELP
A friend of mine picked up the box set of 2 tanks in Hong Kong. We opened them up, and followed the english instructions found online.
1. Charged them up
2. Programmed the ID -> tanks flashed their LED indicating they took the ID programming.
3. Enter any of the battle modes -> nothing happens. The tank doesn't flash (like the translated english instructions indicates), nor do they move.
Am I missing something that wasn't in the instructions? Or do you think the tanks are dead. The odd thing is BOTH tanks do this. I saw a post on here where someone had a similar problem, but no followups had been posted indicating a solution.
could the tanks be dead? Will konami replace them if I send them back to them?
Thanks for the help,
R
Old 01-30-2003, 06:27 PM
Panzer Panzer is offline
Did you move the center switch off of the charge position (the one with the battery next to it)?
Old 01-30-2003, 06:29 PM
Yeah, I follow the instructions exactly. I turn the left switch to OFF. I turn the middle switch to the top position (practice mode), I then push the left position to the top position (for single battle)...and nothing.
Old 01-30-2003, 06:32 PM
It sounds like you set the ID right since you said the tank lit up , but I'll ask this anyway. Did you put the tank under the controller to set the ID? The IR LED that ID's the tank is underneath next to the charge bay.
Old 01-30-2003, 06:33 PM
Yep..I noticed that. Somewhat amusing the design of these things. But yes, I did put the tank under it for the programming.
R
Old 01-30-2003, 06:55 PM
I'm stumped. Did you get the English instructions from the official website? If not, they have them in a PDF. I would get them and read the instructions again carefully. Maybe you overlooked something.
I don't have my instructions here with me but if I remember you turn off the controller set the controller to charge, set the controller to the ID you want, switch the tank on and put it under the controller, turn on the controller then push the ID button till the display says its done and the tank flashes..
Old 01-30-2003, 07:22 PM
Yeah, I've tried that for sure. I've followed both the konami english translation, and the translation done by someone else that I found on this board. They are actually in contradiction on somethings. The non-konami one suggests turning the tank ON to charge it, while the konami one says to turn the tank off....nice and confusing.
Still...not working
Old 01-30-2003, 07:47 PM
Will konami let me exchange/get these fixed if I send them back? Anyone have to do that?
Old 02-21-2003, 05:12 PM
T_T_52
Have you tested your tank on all channels since with my Sherman and T34 will only work on specific fequencys.
Wanted : Cheap RC TANK Cubicle For Sale/Trade 0 03-09-2004 10:07 PM
Fix for tank with poor performance Alard Combat Digi Q 11 09-12-2003 10:17 AM
Possible with ID Azmir Combat Digi Q 0 09-10-2003 02:27 PM
Is my tank dead? Halthek Combat Digi Q 3 05-17-2003 03:11 AM
Tank stopped charging Flawed-logic Combat Digi Q 3 02-03-2003 04:40 PM
