Old 02-15-2003, 11:15 AM
zombiebaby's Avatar
zombiebaby zombiebaby is offline
drag race king
from back 2 front
I want 2 put the rear rims of the axle on the front knuckles has anybody did this and how is it done?
IF I WERE GOD YOU'D SELL YOUR SOUL
Old 02-15-2003, 11:17 AM
sipsap's Avatar
sipsap sipsap is offline
Race them naked
lots of people have done this search for full sized wheel mod. Good luck.
Old 02-15-2003, 11:33 AM
zombiebaby's Avatar
drag race king
thanks for the support
Old 02-15-2003, 12:24 PM
Zephyranthes's Avatar
Blitzer Sonic
Weeeee!
Old 02-15-2003, 12:26 PM
zombiebaby's Avatar
drag race king
how did u do it?
Old 02-15-2003, 04:48 PM
Demon666's Avatar
Demon666 Demon666 is offline
V-tec aholic
to get the front wheels out your gonna have to take and put the nuckles in a vice and push the axle's threw the nuckle using a small nail or somthing as small as the axle. and to remove the back wheel you need to heat the axle while holding them with a pair of plyers and pull the wheel off at the same time.dont rush this prosses becouse you can melt the wheel.i hope this gives you and idea of the prosses.
Old 02-15-2003, 04:54 PM
Pojo's Avatar
Pojo Pojo is offline
Corolla Power!
Send a message via AIM to Pojo
www.questformadness.com
They have pictures and can explain a little better than I can.
Old 02-16-2003, 09:08 AM
crazydave's Avatar
Garage Rocker
If you use a 15 watt soldering iron to heat the axle for a sec, not long enough to melt the plastic, just long enough to soften it slightly, and then the wheels pull off easily. I did the same to remove the pin from the front knuckles, and it came out cleanly pulling it out with needlenose pliers, and did not need glue when I put it back together.
Where I failed was actually drilling the hole all the way through the wheel. I instinctively used my dremel, because I use it for everything. This ended up being overkill, and I elongated the hole, giving it a clown car effect when mounted. Just use a hand drill, you can get one from Radio Shack, and you shouldn't have the problem I did.
Dave
Old 02-16-2003, 09:13 AM
zombiebaby's Avatar
drag race king
could I melt the hole in the knuckle a little bigger and put the pin in from the other side and not have 2 drill a hole
Old 02-16-2003, 01:45 PM
crazydave's Avatar
Garage Rocker
I'm pretty sure the pin is too thin to hold in the wheel if you do it that way.
Check out this save, I drilled the elongated hole out so it was round, then I made a bushing from a pen tip. I think I did pretty good.
Mounting Mini-Z bodies on Xmods neurokinetik XMODS Mods and Projects 18 12-28-2005 05:13 PM
Took the front apart but i cant get it back together,, Please Help! sporttracguy ZipZaps Monster Truck 11 04-06-2005 11:51 PM
how do you put the front axel back itnto the white knuckle Ghost of Akina Bit Char-G Mods and Projects 3 12-22-2002 08:55 PM
zz wheels , front and back Bit Char Bloke ZipZaps 0 11-15-2002 04:22 PM
back on front DeeChan Bit Char-G Mods and Projects 4 10-26-2002 06:48 PM
