Old 12-27-2002, 07:39 PM
spikeymike218 spikeymike218 is offline
TinyRC Sith Lord
heres a simple solution incase your rear axle doesn't snap into the mounting points
if this is in the wrong forum, please feel free to move it to the appropriate one. thanks
what i did was take part of a match and slide through an opening in the center near the axle as described in the pic. make sure the match goes over the axle, not under it. so far it works very well. the match is stiff enough to hold the axle so the gears touch, yet not rough to the point where the axle won't spin at all. heres a pic
Mine: red S2000 27mhz
Hers: blue subaru WRX 45mhz
Mods:
2.6 motor
8.25:1 gear axle
medium tires/soft stabilizer bars
l.e.d headlights
rare earth magnet
Old 12-27-2002, 08:39 PM
scottyboyfun's Avatar
Im a cat, miow.
Nice idea!
What I did when my clone bits axle kept slipping out was to put some exoxy putty over the worn parts, left it to dry, then re-drilled the holes, hey presto, a new axle holder!
----While the putty was still wet I poked out the hole where the axle does go with a sewing needle, so that I did not drill into the plastic later on due to not knowing where the hole is ,all I did with the drill was widen it.
So what do u lot think?
Post it!
Old 12-27-2002, 09:04 PM
henry's Avatar
henry henry is offline
13B REW
great idea! what kind of match u use? the wooden one or the cardboard 1?
Old 12-28-2002, 12:41 AM
TinyRC Sith Lord
they have wooden matches? hehe i used the cardboard ones, watch out though, because not all of them are the same thickness. you want one that is pretty thick and not too thin. i would post pics, but i don't have a good digital camera.
Mods:
2.6 motor
8.25:1 gear axle
l.e.d headlights
rare earth magnet
Old 12-29-2002, 02:13 AM
cowfish_29's Avatar
yellow fish forever!
My gears were so bad that if you turned left, the gears would completely disengage and then proceed to lock up. This fixed it..very nicely.
i cut a wood match in half till it slid snugly in that hole you were showing, and the axle was just like new. Good stuff. Once again, my subaru just BARELY works. wonder how long it will last this time.
Old 12-29-2002, 02:42 PM
Im a cat, miow.
I had worn axle mountings!
I fixed mine by using modelling epoxy putty.
1. I took the axle out
2. Put the putty at both sides where the axle clips in.
3. Get a sewing needle and push a hole through the
original axle hole.
4. Let the putty dry.
5. Cut a THIN SLOT for the axle to slide though.
6. Put ur axle in!
7. Done!
Post it!
Old 12-29-2002, 02:44 PM
Im a cat, miow.
original axle hole, Allowing enough room for the
axle to move freely.
6. Put ur axle in!
7. Done!
Post it!
Old 01-01-2003, 05:23 PM
Im a cat, miow.
I tried the glue gun thing n found that it stuck to the axle!
I do think that it must have been the type of glue i was using, cos there are about 3 different types!
Post it!
Old 01-27-2003, 08:41 PM
FMZPLAYER1 FMZPLAYER1 is offline
Hmm, how about piece of a spring?
I like the match stick idea, and came up with a similar plan, involving a piece of spring wire. I stretched out an old tape player spring, and cut and looped one end around a small screw, which just fits the holes under the motor. The other end of the spring is bent so that it just lightly holds the axle in place.
The hardest part is bending the spring to give just the right amount of contact, without slowing axle down too much. I have my spring directed more towards the geared side of the axle. (since that was the end that was vibrating the most)
Old 02-05-2003, 05:45 PM
Zephyranthes's Avatar
Blitzer Sonic
I use a toothpick and tape it on. It works perfectly fine, and its really easy to make the holes for the wheelie bar without messing up the tape.
Old 02-05-2003, 06:40 PM
~SnakeBitRacer~
SpikyMike
1. You live in SJ? Me too! Wanna meet-up sometime?
2. You hear bout Microgames in Milpitas? Im' goin hopefully
Old 02-06-2003, 12:40 AM
TinyRC Sith Lord
Originally posted by ~SnakeBitRacer~
SpikyMike
yeah i live in san jose. yeah i heard bout the microgames, unfortunately my projects in school keep me very busy and i usually don't have any free time.
Mods:
2.6 motor
8.25:1 gear axle
l.e.d headlights
rare earth magnet
Old 02-06-2003, 03:28 PM
hogjowlz's Avatar
hogjowlz hogjowlz is offline
Old 02-06-2003, 08:36 PM
~SnakeBitRacer~
Were in Sj do you live? I live less than a mile from were first street starts in alviso. By 237 in Lamplighter
Old 02-07-2003, 02:24 AM
TinyRC Sith Lord
i'm over by kiely and saratoga, pretty close to Valley Fair.
Mods:
2.6 motor
8.25:1 gear axle
l.e.d headlights
rare earth magnet
Rear Axle Bearing I-luv-Goin-Fast ZipZaps Mods and Projects 0 03-28-2005 01:58 PM
Repairing a worn rear axle retaining slot rfnagel ZipZaps 5 01-22-2004 01:37 PM
Rear Axle Tip nrmcj Bit Char-G / MicroSizers 8 05-18-2003 01:47 PM
