Old 06-03-2002, 07:13 PM
StreetRacer StreetRacer is offline
Question what dose a boost do??
ive heard of people talking about boost and other stuff like that and i have no clue what it is??? can someone explain to me what it is???
__________________________________________________ __
RX-7 with a 3.0
Old 06-04-2002, 01:13 AM
tinyrc's Avatar
tinyrc tinyrc is offline
It's a replacement chassis, and it requires the 4ch controller; when you apply the Boost, it effectively adds "1.0" to the motor speed, making for example a 1.0 into a 2.0 and a 2.2 into at 3.2 (etc.).
Old 06-04-2002, 02:21 AM
323iT's Avatar
323iT 323iT is offline
3.0 to a 4.0
Old 06-04-2002, 05:22 AM
The Thunderer's Avatar
The Thunderer The Thunderer is offline
Wow, I don't even have a 3.0 yet and I can boost to a 4.0 when it comes in???? KEWL!!!!
"Its the least I can do for the Captain of the Enterprise."
"Where there is lightning, there is The Thunderer."
Old 06-04-2002, 03:55 PM
can someone explain to me step by step how i make this boost stuff work???
Old 06-04-2002, 05:51 PM
TheFanMan's Avatar
Shoot To ILL
actually
it actually gives you dual speeds, you don't HAVE to have a multi controller, but if you have one, then that's what the "action button" is for. hit it and bam! quik boost
Custom:
Toyota Trueno
tires: soft
gear: light blue
shocks: mediums
motor: 2.2
Old 06-04-2002, 07:18 PM
how much does a boost cost, and how much does a boost controler cost???
Old 06-05-2002, 10:05 AM
ylexot ylexot is offline
Yes, you do HAVE to have a multi controller for the booster cars. They use a different control encoding in the frequency. That's why there's an A-B-C switch on the multi controller. A for non-boosters, B for boosters, and C for future products. C also controls the booster, but you lose the slow speed ability (constant boost).
Step one - Buy Booster car set.
Step two - Buy Multi controller
Step three - Push boost button to go faster.
Boost is non-existent on other cars.
I'm not sure about the "adding 1.0 to your motor", but the booster with a 2.2 is faster than a normal 2.2, but the slow speed is slower than a normal 2.2.
Xanavi Hiroto Skyline GT-R 57MHz
Booster 35MHz
MicroQ Porsche 45MHz
Peugot Bullet 49MHz
Skyline GT-R Bullet 40 MHz
WRC Impreza Nikko iRacer
Subaru Impreza and Toyota Bb Bodies
Old 06-05-2002, 11:01 AM
tinyrc's Avatar
We have the controller available in the Shop, and the Boost chassis are on the way.
Old 06-07-2002, 11:47 PM
ViperKid's Avatar
ViperKid ViperKid is offline
Redneck Drifter
will the boost only last fo so long? will the chassis fit other badys too?
Old 06-19-2002, 11:46 AM
hoyboy_92 hoyboy_92 is offline
Well from what I understand when the car is running without boost it is a lot slower than normal e.g. a 3.0 motor will run much slower and therefore controllable. When you hit the boost button it gets full power and runs like any other 3.0
Useful when you need to slow down for corners and tricky bits, but it is not a way of getting a 3.0 to go like a 4.0!
But then my booster set arrived dead in the post so I haven't had a chance to try it yet :-(
Old 08-15-2002, 11:09 AM
striderpunk striderpunk is offline
Hypnotic ain't she.....
man that sucks your car arrived dead man sorry
Old 08-15-2002, 07:00 PM
_NiTrOuS_'s Avatar
_NiTrOuS_ _NiTrOuS_ is offline
someone once said that the way the boost works is that the machine flicks the power on and off really fast so it goes slower, then when you press the boost button it goes full speed.
Old 08-21-2002, 02:05 PM
baleisen baleisen is offline
Micro R/C'er in Da Burgh
Send a message via AIM to baleisen
Boost
Please let me explain this.
The car must have the 'booster' RX deck. The X-mitter must be the 4 band controller. When the car is raced, it normally will travel at about .7 normal speed. Press the boost button and you get full speed. The 1.0 and 3.0 motors don't respond properly. Don't use them. You can burn out the receiver. (Go IR.) I haven't tried the 3.8 motor yet. Hopefully next week.
Concerning IR: The steering actuator of a BCG is just that, a magnetic actuator. This is not the reason that the IR conversion doesn't have prop steering. Magnetic actuators have been used in R/C planes for 50 years. We fly mico-planes with them today. Check out rcmicroflight.com
I am considering building an 0.020 powered R/C car. I have to find a proper flywheel.
BAE
Smaller models, more control
Old 08-21-2002, 07:07 PM
tinyrc's Avatar
Wow, those little planes are amazing! Can you buy them, or are they all self-built?
Boost Button otobot Bit Char-G / MicroSizers 4 02-24-2004 01:13 AM
? about boost cars shinigami579 Bit Char-G / MicroSizers 4 01-21-2003 09:54 PM
To Boost, or not to Boost.... DarthRacer Bit Char-G / MicroSizers 2 11-21-2002 12:49 PM
to boost or not to boost? boosted Bit Char-G / MicroSizers 3 11-12-2002 08:18 PM
K.I.T.T turbo boost? Racemonster505 Bit Char-G / MicroSizers 2 09-26-2002 07:24 PM
