01-21-2003, 05:57 PM
Zip zap rims on BitCharG
I looked for this on the forum but couldn't find an older thread.. so here's my question.. my RS has a bunch of the rims and axles, are they a direct replacement for bitcharg or do i need to do some modding? and what kind?
From Bit Char-G's to 1/10 Scale Nitro
01-22-2003, 10:28 PM
next time u go to radio shack, can u get me back hubcaps, and front hubcaps. i also need the front steering knuckles.
01-23-2003, 10:05 PM
I are smart....
The rims in the back are a direct replacement. Go crazy. Now you just have to figure out the front
01-24-2003, 04:26 PM
'00 Subaru Impreza 2.5 RS
I think for the front, you can just swap the steering knuckles. But I'm not positive about that. Worst case, pull the pins holding the wheels to the knuckles on both cars, and glue the ZZ pins/wheels to the MS knuckles. But for the back, it's a direct swap, just like was said alread. The ZZ red turbo gears work pretty well in a MS with a 3.8, by the way!
27MHz Microsizer White Peugeot 206: 3.8, NiMH
49MHz Microsizer Yellow Lancer Exolution: stock
27MHz LXX Char-G Xanavi Skyline GT-R: 3.0
27MHz ZipZap Yellow F&F Civic: 2.6, Carbon Fiber-look hood, lowered, sport tires, turbo gears
01-24-2003, 10:41 PM
I are smart....
The front is a direct swap but the bigger rims/tires will rub on the chassis and maybe the body. My point was that you have to find the front zz knuckles/rims for your bit.
I have zz rims on my bit and had to do some sanding of the chassis/body.
01-24-2003, 10:42 PM
I are smart....
Here's the skyline shell that needed some sanding. My rx7 shell did not need to be sanded.
01-24-2003, 10:43 PM
I are smart....
Final pic
