Old 01-20-2003, 03:26 PM
Pietak440's Avatar
Pietak440 Pietak440 is offline
Project D
Send a message via AIM to Pietak440
Need a little help
well, my motor sounds like it is about to explode, and I need help on what I should do about it. It's a 1.0 and I've had it for about 3 weeks.
Let Us Know!!
- Honda S2000
- RealTime Toyota Celica
- Nissan Skyline R34
- Toyota Treno AE86
- Mazda Rx7 FD
Old 01-20-2003, 05:03 PM
t-squared's Avatar
t-squared t-squared is offline
Bit Obessed...
sounds........awful.......my sounded worse, it sounded like a kid screaming.......
anyways, it sounds like its dirty or something, why don't you try to clean it or maybe lube it......
Old 01-20-2003, 05:07 PM
JTM's Avatar
JTM JTM is offline
1 4M 70 1337 4U
Send a message via AIM to JTM
i hear axles, that may be your idler gear making that noise.
Old 01-20-2003, 05:23 PM
PWalk's Avatar
PWalk PWalk is offline
Where's the Beer?
Send a message via AIM to PWalk
sounds like a gear to me, lube them or just go buy a new motor.
I'm taking the Bit's offroad!
Old 01-20-2003, 05:34 PM
Pietak440's Avatar
Project D
There are no gears on it at all, not even the gear that goes on the motor, and it sounds the same even when all gears are on. I've been thinking of dunking it in rubbing alchohol, but I wonder if there is another way to lube the motor. (It is NOT the gears that squeak.)
Let Us Know!!
- Honda S2000
- Toyota Treno AE86
- Mazda Rx7 FD
Old 01-20-2003, 05:38 PM
Canadian Bit's Avatar
Canadian Bit Canadian Bit is offline
You can't beat it.
It sounds like dust in the space where the piece of metal that turns the first gear meets the outside of the motor.
My Garage: One Lamborghini Jota, Murceilago, Diablo, and a Countach.
One Ferrari Enzo.
One Porsche 911 GT2s, and 1 911 Turbo.
One Mercedes SL600.
1 Mitsubishi Eclipse.
Two 95' Mazda RX7s.
And 4 dozen Toyota Supras, 6 Skylines, and a Hino Blue Ribbon Bus from the Keisei Line.
Old 01-20-2003, 06:20 PM
stevensmd3 stevensmd3 is offline
Send a message via AIM to stevensmd3
if it was me i would have thought it was a gear
White Skyline
2.6
type 3 suspenion
blue gears
hard ribbed tires
Old 01-20-2003, 06:31 PM
Superimport2nr Superimport2nr is offline
MASTER PAINTER
Send a message via AIM to Superimport2nr
try lubing
Old 01-20-2003, 06:41 PM
Pietak440's Avatar
Project D
what lube would you suggest?
Let Us Know!!
- Honda S2000
- Toyota Treno AE86
- Mazda Rx7 FD
Old 01-20-2003, 06:57 PM
MASTER PAINTER
graphite or VASELINE
hehe, im just kidding about the vaseline(that'll kill the car)
yu should use graphite lube or some sort of WD40
Old 01-20-2003, 08:07 PM
t-squared's Avatar
Bit Obessed...
When my motor was making awful sounds....a combination of WD-40 and baby powder worked for me
I sprayed the WD-40 where the shaft meets the brass bushing and dunked it in babypowder afterwards....
just make sure that you don't go overboard and coat the whole thing in WD-40 or else dirt and more crap will stick to it....
Old 01-20-2003, 08:23 PM
JTM's Avatar
JTM JTM is offline
1 4M 70 1337 4U
that quote, i put buisness and with backwards, lol...
Old 01-24-2003, 08:55 PM
Pietak440's Avatar
Project D
I'm afraid that your suggestion didn't work, in fact, it sounds worse! I need help.
Let Us Know!!
- Honda S2000
- Toyota Treno AE86
- Mazda Rx7 FD
Old 01-25-2003, 10:06 AM
cowfish_29's Avatar
yellow fish forever!
sounds like a bearing place is dry. when these motors die its hard to fix them. 1.0s are cheap. if you want another one you can get one cheap here-
http://www.tinyrc.com/shop/products.php?pid=2
along with lots of other (faster) motors. yes.
