Old 01-22-2003, 12:50 PM
Minisizer Minisizer is offline
Angry Fullsize Wheelset Help!!!
Can some one please tell me why the pins always come out bented when I try to hammer them out with a nail and hammer!!!
Old 01-22-2003, 01:05 PM
airbob20's Avatar
airbob20 airbob20 is offline
Kid at Heart
Send a message via AIM to airbob20
i donno..
in fact the only insight i can give on this subject is that when i remove the pins i grab the head of the pin with needle nose pliers. they seem to come out easily enough to me.
Doug
Doug
Old 01-22-2003, 01:15 PM
savage sound's Avatar
savage sound savage sound is offline
I used a soldering iron to heat the pin. then quickly pulls the head with a set of plyers. the only prob i run into is the replacement wheels. i tried putting some on that i got off a rear axel, but i cant get the wheels to run stright. the car keeps pulling from one side to another. i dremmeled the body so they fit, but the friggin thing will not roll right. any segestions?
jack of all trades master of nothing!
Old 01-22-2003, 01:18 PM
airbob20's Avatar
Kid at Heart
you took both wheels off the same axle?
if so did you either trim the spacer off the non gearside wheel or add a spacer to the gearside wheel?
other than that maybe your pins are wobbling loose i donno
Doug
Doug
Old 01-22-2003, 01:25 PM
i trimmed the spacer on the nonspur side and the two lil-pin looking spacers on the spur side and it still was being pain. what wheels do you all use when swapping?
Old 01-22-2003, 01:33 PM
airbob20's Avatar
Kid at Heart
bit rear wheels
i just use a set of rear wheels like you do. hmm this requires some research. let me look into this a bit.
Doug
Doug
Old 01-22-2003, 01:54 PM
rabbitsperm rabbitsperm is offline
i used a kit racer rear axle. so i used two rear kit wheels for my full size wheel mod. but i had to tear up two axles to get the two wheels with spacers then i just filed them down to size.
rabbitsperm
Old 01-22-2003, 03:21 PM
strider_mt2k
I imagine the hole for your axle shouldn't be too big either.
That could cause wobble.
Old 01-22-2003, 06:23 PM
Zephyranthes's Avatar
Blitzer Sonic
Hammering the nails in OEM cars is a lot easier. Because of the lack of quality, the nails aren't secured as well. That's what I did, and I now have a full size wheel set. Only drawback is that the front wheels touch my Mazda RX-7 body making it swerve to the left.
Fullsize wheel mod and bodies... Vyrus Bit Char-G / MicroSizers 4 08-18-2003 09:29 AM
Fullsize wheelset? Zephyranthes Bit Char-G Mods and Projects 20 02-18-2003 02:32 AM
Fullsize Wheelset Help Needed Minisizer Bit Char-G / MicroSizers 1 01-14-2003 11:34 PM
Full Size Wheelset....screw that! shocon2k Bit Char-G / MicroSizers 7 01-05-2003 07:52 PM
fullsize wheelset concerns sine -''-..- Bit Char-G Mods and Projects 2 10-14-2002 07:57 PM
