Old 01-21-2003, 10:35 AM
hogjowlz's Avatar
hogjowlz hogjowlz is offline
dual battery control??
how do you keep your cars from flipping over? i installed some springs on the front and it seems to help a little bit but it still aint that hard to flip over even on thick carpet. any suggestions?
Old 01-21-2003, 11:17 AM
nghts's Avatar
nghts nghts is offline
Send a message via Yahoo to nghts
Im pretty sure that people install a wheelie bar, there is a tutorial on questformadness.com I think about it
AMC Represent
Old 01-21-2003, 11:36 AM
Namuna's Avatar
Namuna Namuna is offline
If you're asking how to NOT barrel roll going into a turn at full throttle with a Dual-Cell mod, then I'd say you don't have much of a chance...But.
Here's a few thoughts...
- Pulse the throttle
Instead of running it full sauce into the turn (which you KNOW is going to cause the roll), let off the gas and let it roll into the turn. Then when it's most of the way through the turn gas it up again.
- Use harder compound tires
The harder the compound, the easier it'll drift. You're barreling because the tires are holding instead of giving.
Good luck.
Old 01-21-2003, 11:47 AM
hogjowlz's Avatar
i have one from a kit racer but it doesnt seem to weigh enough to make a difference. i guess ill put some lead weights under the shell.
thanks namuna. but im looking for all out balls. heh. i just gota come up with some weights and reinforcments for the chassis.
Old 01-21-2003, 03:07 PM
Bunta Bunta is offline
Hi peeps,,
I don't want to repost an old thread,, and I don't know how to link it here,, but my solution to your flipping problems can be found if you do a search of this forum for
bunta's mod
it's the second thread called bunta's "secret" mod!! In that thread I describe a wing that goes under the car that keeps your car from flipping. It's not the easiest to find....
good luck with the mods
-Bunta
Custom Mods R us
Old 01-21-2003, 03:12 PM
dabigpig's Avatar
dabigpig dabigpig is offline
http://www.tinyrc.com/forums/showthr...ght=buntas+mod
*** AMC Veteran ***
-- ^-_-^
Old 01-21-2003, 03:19 PM
hogjowlz's Avatar
hmm seems like a good idea. i think ill add more weight to the rear first since watchin your car do wheelies is pretty fun.
Old 01-21-2003, 09:36 PM
bdebde's Avatar
bdebde bdebde is offline
That's all folks
HARD TIRES in front does it for me, lets the front end push while turning. I use the Microsizer hard ribbed in front.
That's all folks!
Old 01-21-2003, 11:36 PM
dohc's Avatar
dohc dohc is offline
TinyRC Hacker
i use cat5 wires so my bit charg wont flip over on a turn and ish. check out my bit charg. hope this helps!
Old 01-21-2003, 11:37 PM
dohc's Avatar
TinyRC Hacker
another angle. sorry bout the blurry pics
Old 01-22-2003, 02:43 AM
hogjowlz's Avatar
nice
More powerful steering for 2-cell mod? bonus: faster charging for dual battery mod Chris Bit Char-G Mods and Projects 1 11-23-2002 07:24 PM
My ZipZap now runs circles around my Bit! (dual batt success) caver01 ZipZaps 16 11-05-2002 11:22 AM
dual battery mod no speed increase? delmonk Bit Char-G Mods and Projects 7 10-17-2002 12:10 AM
ZZ Dual Battery Mod Mattydiah ZipZaps 1 10-14-2002 10:58 AM
