01-19-2003, 06:46 PM
drag race king
this is a huge problem I,m having
when I put my rear axle in it really loose it look like I have changed it so much that I have worn the nubs that keep it held up in is there anyway 2 fix it or am I screwed
IF I WERE GOD YOU'D SELL YOUR SOUL
01-19-2003, 06:49 PM
1 4M 70 1337 4U
glue
i wish i could use the IMG tag in signatures....
01-19-2003, 06:55 PM
drag race king
that would stop the axle from spinning u think?
01-19-2003, 06:57 PM
ok if the rear axle dont fit n e more, im guessing u r scruedlike they're loose.
i would buy a new one.
JTM, glue dont work if glue happens ,
the rear axle gets stuck
A man who desired nothing is invincible.
01-19-2003, 07:11 PM
Got Mini-z?
there was apost somewere saying that if u put a lil pole throught this hole in the back of the chassi(right under the engine under the chassi)it should stay...
01-19-2003, 07:30 PM
1 4M 70 1337 4U
if you use elmers glue on the bottom of each side, then wait for it to dry and trun it with your fingers itll break loose (doesnt like to stick to smooth metal) and create a nice snug vibration free area.
01-19-2003, 07:36 PM
drag race king
thanks thats a damb good idea I was thinking model glue but elmers would work better
01-19-2003, 07:40 PM
Race them naked
heat an exacto or razor blade and cut a little slit in front of where the axle snaps in then bend it in to make the hole more snug
01-19-2003, 10:01 PM
i read somewhere u can slip a match through the two holes on either side of the axle and it will hold it up.
u might need to cut the match to fit or use a toothpick. if u look i think u will see. its through the hole that u can see the battery through and the other hole on the other side
01-19-2003, 10:05 PM
TinyRC Sith Lord
i was the one who came up with the match idea. heres a link to my post about it:
http://www.tinyrc.com/forums/showthr...le+not+staying
Mine: red S2000 27mhz
Hers: blue subaru WRX 45mhz
Mods:
2.6 motor
8.25:1 gear axle
medium tires/soft stabilizer bars
l.e.d headlights
rare earth magnet
01-19-2003, 10:13 PM
see kids these days are so smart
