02-20-2003, 11:08 PM
My DRR setup
From left to right:
Fairlady Z Digi Q
Fairlady 350Z Bit-Char-g (Boost)
Precious clone with 2 cell wheelie mod
DRR (see sig)
Bit-Char-G
*Fairlady 350Z: 2.2 motor, boost, 2.4V or 3.6V NIMH mod (in stock location),
*Precious Skyline R34: Fuk'd up leftover parts (canabolized car...heh)
Digi Q
*Fairlady Z: Stock
Mini Z
*Suburu WRX Rally: Stock (for now)
*Blue RX7 Autoscale Body
Dynamite Rocket Racer
*McLauren F1 Blue: Novak SPY ESC, Novak XXL AM receiver, TO Elite Modified Coreless, 7.2V NIMH 6 cell 700mAH AAA, 13T pinion, front soft springs, DRR foam tires, ball bearings, foam bumper. (rear aluminum bulkhead on order)
02-20-2003, 11:12 PM
you can see the Novak XXL and Novak Spy ESC underneath the center mounted batts. This gives my setup excellent stability and balance. The total weight for the 6 batteries is about 78 grams (each AAA 700mah NIMH cell is about 13grams).
Bit-Char-G
Digi Q
*Fairlady Z: Stock
Mini Z
02-20-2003, 11:18 PM
TO Elite Micro Mod Motor and HPI 13T metal pinion
Bit-Char-G
Digi Q
*Fairlady Z: Stock
Mini Z
02-20-2003, 11:23 PM
another pix of the SPY ESC and batts
Bit-Char-G
Digi Q
*Fairlady Z: Stock
Mini Z
02-20-2003, 11:24 PM
Soft springs in front suspension and foam bumper. stock servo.
Bit-Char-G
Digi Q
*Fairlady Z: Stock
Mini Z
02-20-2003, 11:26 PM
3M double sided foam tape to keep the batt holders in place.
Bit-Char-G
Digi Q
*Fairlady Z: Stock
Mini Z
02-20-2003, 11:29 PM
power switch and Dynamite Foams
Bit-Char-G
Digi Q
*Fairlady Z: Stock
Mini Z
02-21-2003, 01:37 PM
Are those the foam tires from Dynamite?
Thanks.
02-21-2003, 01:44 PM
Yes, they are Dynamite foams. I haven't driven on them yet cuz i just got them in a few days ago. I had Tamiya mini 4wd f1 wide foams on before and they were much thinner so the ride height was lower. I like the dynamite foams much better because of the added height.
Anyone know of any WIDE wheels and tires that'll fit our DRR (like from a ABC SP or something)?
-djpj
Bit-Char-G
Digi Q
*Fairlady Z: Stock
Mini Z
02-23-2003, 08:58 PM
yeah....the abc dtm wheels, front and back will fit. I have them on my DRR with the bushings that are used for the DTM so i don't know if the rr bushings will fit. The ABC bushings have a small flange on them. Any wider up front and you're gonna have probs with the tires touching the servo connection or even the foam bumper.
