Old 01-08-2003, 01:47 PM
wO[RX
Help a new guy
Help, I have an American Hobbico Microsizer. When I am running it, it seems to stop for no reason. Then if I give it a little push, it starts going again.
It's brand new, no dirt, nothing. The antenna seems a little short. Should I put a different antenna on it?
How do I know what wire to buy to replace the antenna if that's the problem?
thanks,
Andrew
Old 01-08-2003, 03:36 PM
ib311's Avatar
ib311 ib311 is offline
Promoted to Pleb
You can send it back. Try a different room in the house. Take it back to the store. It could be because of interference from the kitchen or computer or TV or something like that. Also, those cars only have about 5-8 feet of range out of the box. So, if it's father away than that...that could be the reason it stutters or stops.
You need to have some soldering skills to replace the antenna in the car. I would use 24g solid copper wire or cat5 cable.
You could also try the crip cap mod which is at QFM and also posted somewhere in these forums. Do a search. : )
Old 01-08-2003, 03:41 PM
wO[RX
Cool thanks.
I forgot to mention too ..... I put a faster motor in it. Maybe it's loosing contact with the car somehow.
Old 01-08-2003, 03:57 PM
ib311's Avatar
Promoted to Pleb
I don't think that there's a contact problem. Just try what I mentioned and post again if your problem persists. Good luck!
New guy DexGtr Bit Char-G Mods and Projects 2 11-23-2005 10:00 AM
This guy trying to screw people Kubrel XMODS 34 01-05-2004 10:59 PM
New guy here, don't want to annoy anyone... FordTrucktexan ZipZaps SE 4 12-10-2003 11:31 PM
New guy important Q : buying one , what to look for ? zaidallas Bit Char-G / MicroSizers 1 06-23-2002 09:19 AM
