Old 01-01-2003, 07:04 AM
scottyboyfun's Avatar
Im a cat, miow.
Proportional Speed
I know some people have controlled their bits using real Radio Control transmitters, when u did, did u get proportional speed?
So what do u lot think?
Post it!
Old 01-01-2003, 12:44 PM
Im a cat, miow.
I know sum1 here has tried it! All post ur ideas! i dont want 1 of those crap posts!
Post it!
Old 01-01-2003, 01:54 PM
hogjowlz's Avatar
hogjowlz hogjowlz is offline
you would have to seriously mod the car.
Old 01-01-2003, 05:03 PM
Im a cat, miow.
I was gonna modify my tomy controller,so it could pulse, but i thought that if i used a real transmitter,it would already pulse the signal,therefore creating variable speed!
Sum1 try the real transmitter idea!
All u have 2 do is open up ur char g controller, read the crystal frequency, then get 1 of these and put it in ur REAL transmitter.
Theres been a loada people viewing,but no 1 adding 2 my thoughts!
Post it!
Old 01-01-2003, 10:14 PM
shocon2k
Your car's PCB is a radio controlled on-off switch. A proportional controller will send proportional signals, but your car would need an electronic speed controller (usually a $100 item) to control the proportional throttle. Also, to have proportional steering, you would need a steering servo with feedback.
Old 01-02-2003, 01:43 AM
slugbugg slugbugg is offline
I KNOW NOTHING!!!
all I've come up with so far
This is the best idea I've had other than buying one of those 1/60 scale for proportional cars.
http://www2.towerhobbies.com/cgi-bin...?&I=LXAVS3&P=7
It is a combination 5 channel receiver/esc but still on the big side and it would need to be changed to a land frequency and it needs 6.0 to 7.2 volts.Unless someone knows of a cheap,super micro receiver.
Puchi maru 1/60 fully proportional ($89.99)
http://h1070586.hobbyshopnow.com/ser...ducts&tag=srch
http://www.waigohobby.com/yo_petit.htm
This guy has some very small R/C equipment but it gets expensive.
http://litke.info/uPlanes/radio.html
Old 01-02-2003, 09:25 AM
hogjowlz's Avatar
running a pulse circuit from the controller would be interesting.
Old 01-02-2003, 12:32 PM
shocon2k
Yeah but how would you rig up the boost button on your remote? Or would you run it so the boost kicks in half a second in or something? That way you could tap in tight turns and open it up on the straightaway.
True proportional doesn't seem feabible, but these 2 speed ideas are cool.
Old 01-03-2003, 03:27 AM
Im a cat, miow.
I think the way it would work would be to have the normal forward and backward at full spped (AS THEY ALREADY ARE)
and to have a pulsing circuit connected in parallel to forward switch,
this circuit would have a switch on it, and when u pressed it the car would run at 1/2 speed.
ALSO 1 thing I was wondering, Why does a boost car at full boost run faster than a normal bit with the same specs?
Is there a resistor or transistor that needs to be changed to achieve the same speed?
Post it!
Mini-Z top speed comparison nrsjs XMODS 48 01-24-2004 03:10 PM
Proportional Controller EMULATOR ph2t Bit Science 88 01-21-2004 04:12 PM
2.2 2 speed vs 2.6 1 speed eman1 Bit Char-G / MicroSizers 0 12-16-2002 08:34 PM
