Old 12-11-2002, 02:25 PM
TemjinNeo78's Avatar
TemjinNeo78 TemjinNeo78 is offline
Bit Drag Racer
Send a message via AIM to TemjinNeo78
The best gearing+motor combination!:D
When i say best i mean top-speed wise
Ok well on my best bit char-g i used to have the following:
Dark Green Gears(Bit Racer 3:43 smallest ratio)
Red Lucifer Rotor(3.0)
After discovering the extremely slow acceleration of my rc, i trie different combinations. So i tried a 2.6........ it happened to have good acceleration, but thats not what i wanted. I tried myself another step down to the 2.35 or the NOS zz motor, whoa you wont believe the results i have ogtten with top speed. I fratically floored the throttle and watched it take off to a rough and slow start. I just got faster, faster and faster, it wouldnt stop it continued to get even faster..... I am about to try the LXX "3.0" rotor with this gearig combination, ill check in once i get my finds, but as it stands right now, the ZZ NOS motor is the best when it comes to this.
Old 12-11-2002, 02:56 PM
Bit Drag Racer
after more tests the 2.2 motor came out on top, i believe with the smallest gearing you need to use the smallest motor i dont have a 1.0 so thats as low as i will get until i get a newer bit. The 2.2 as the only one with a combination of top speed and acceleration, so so far 3:43 gears and a 2.2 motor rise to the top
Old 12-11-2002, 03:25 PM
Bit Drag Racer
what i once more discovered.
Well after experimenting more i tested out the 2.1 motor and the acceleration was just crazy and the top speed was great, you people may think that this thread is stupid but im just trying to help you people out and so that you can always reference to this thread. So far the 2.1(zz turbo motor is the fastest with the smallest possible gear combination) I have found this out:
smallest usual revolutions per-minute(or smallest rpm motor all except the performance z motor)
the smallest gear combination=highest top speed
highest revolutions per-minute(highest rpm motor)
smallest gear combination= bad acceleration and bad top speed.
Since most of the smaller motors have great torque to push these gears, i believe that is why this is evident
Old 12-11-2002, 03:44 PM
1llusI0n 1llusI0n is offline
BitOnline GM
Send a message via AIM to 1llusI0n
Nice gj temjin
Old 12-11-2002, 05:39 PM
Bit Drag Racer
zip zap motors in combo with the bit racer gearing system:
1.6= slow accel slow top speed
2.1(turbo)=slow accel high end top speed
2.35(NOS)=high accel mediocre top speed
bit motors in combo with bit racer earing system:
2.2=good accel bad top speed
2.6=bad accel bad top speed
3.0=bad accel bad top speed
ill try to get myslef one of those bitmod1 motors some time around here ill post in this thread wehn i order one and then get one.
Old 12-11-2002, 06:30 PM
MTL's Avatar
MTL MTL is offline
www.d1gp.com
Send a message via AIM to MTL
it all boils down when u get the 3.8
the best top speed of all motors it seems, but crap tourq
Old 12-11-2002, 07:17 PM
JBit's Avatar
JBit JBit is offline
go Go GO, JBit Mifune!
Here is my lil comparo - orange gears are the higher ratio gears, teal is the lower ratio.
On a rating of least fun to most -
2.2 with Orange - bleh. Quick start but definitely held back on top speed even on a short course.
3.0 with Teal - I'd recommend only for big courses - on small courses the lack of accel/torque is really evident, but this combo has the highest top speed (no good on a technical course anyhow)
2.2 with Teal - the 2.2 has more torque so I barely noticed a lack of accel here - the top speed was way better than with orange but still less than 3.0 with either gear. I like this combo for Short courses, and can hold its own in long courses.
3.0 with Orange - nice accel, makes up for natural lack of torque of 3.0 - and the 3.0 pushes the top speed over that of the 2.2 with teal. Recommend short and long courses.
Overall I might even choose the 2.2 with teal in races since the 3.0 has a tendency to seize up, requiring a quick (back/forth) punch of the controller to get it going (never bad enough to have to push the car manually)
The Mach w/DKS 3.4 Darkside Rotor.
Old 12-30-2002, 03:35 PM
Silent_NightR34's Avatar
Got Mini-z?
if u put a double or triple battery mod on the 3.8 motor with them gears wont it be faster than the rest?
Old 12-30-2002, 04:38 PM
skater252000's Avatar
skater252000 skater252000 is offline
Send a message via AIM to skater252000
What gears should I use if I'm using a 3.5 BitMod1 motor with a dual cell conversion? I'm lookin for a set up that would have good torque and a high top end if possible.
F*S*U* 200?
Gearing for mini-x bluemax_1 Mini-X 16 04-15-2003 07:59 PM
Gearing Info nrmcj Bit Char-G / MicroSizers 6 01-25-2003 12:35 PM
Gearing Ratios? LCKKN]HT Bit Char-G / MicroSizers 2 11-16-2002 10:37 PM
Special editon gearing vrs normal gearing Smurf Bit Char-G Parts and Hop-Ups 2 10-09-2002 11:08 AM
Gearing? Ohm ABC DTM X4 1 09-22-2002 12:38 AM
