08-09-2002, 05:30 PM
Bit Char-G does not run
Ok, this is strange. The car works when it is on the charger. The wheels turn and the motor runs. However, when I take it off the charger, it does not work anymore. Any ideas?
08-09-2002, 05:33 PM
Here is what is up. If it has the battery in it and it is on the charger, it works. If I take it off the charger, it does not work. If I put it on the charger without the battery in it does not work.
Any ideas?
08-09-2002, 07:13 PM
It sounds like your battery is not touching both contacts; so it works fine when plugged in, but the battery itself is not charging and cannot supply power when unplugged. Lift up the PCB and check that the contacts are holding the battery snugly. If that doesn't work, let us know.
08-09-2002, 07:48 PM
or ur battery is just dead...
