Old 01-02-2003, 12:20 AM
jerm781 jerm781 is offline
hey IRC
why is the Activ Road Racer 1:24 so expensive? with electronics in it it will cost more than a micro rs4. What makes this car so special? And will there be a rtr version of this car or the 1/24 WWS pro? I am good with changing parts in the cars but assembling and putting in electronics is a little diffrent. I have a Mini-X, Rocket Racer, and a Micro RS4 all ready to run except Mini-X (I needed a controller). Is it common for people to switch elecronics between cars or should all cars have there own? ESC's and servos are expensive.
Old 01-02-2003, 12:54 AM
irc irc is offline
The Aktiv car is more money because of the aluminum construction and the fact that it comes with full ball bearings and a 180 motor. If you were to view one up close you would be amazed at how low the price really is. A good 1/24 car kit like the ABC is less money but you still need to add bearings and a 180 motor. By the time you add these items along with a few aluminum hop ups you will have spent more than the Aktiv price. I have had a few customers purchase the Aktiv car and the hitec HS 55 servo and then use the TX/ESC and radio from there Rocket Racer. This is a good way to go and it is very easy to swap the electronics.
" THINK FAST "
Old 01-02-2003, 12:59 AM
irc irc is offline
The WWS PRO 1/24 will be less money than the Aktiv (Around $95) but the car still requires assembley. It will have a 180 motor and foam tires but ball bearings and an aluminum motor mounts will be optional. You could also install all the electronics from your rocket racer in it.
" THINK FAST "
Old 01-02-2003, 09:33 AM
thanks for the info. I might look into the WWS when you get them in. And do you carry bearing for the Rocket Racer?
Old 01-02-2003, 11:59 AM
irc irc is offline
As of now we do not stock any parts for the rocket racer. You can buy the bearing from TRC. The Mini X bearing work for the front rims and rear axel!
" THINK FAST "
Original ZipZaps & More (Hey Tiny?) Stridex ZipZaps SE 8 01-04-2006 11:09 AM
Hey, thinking about x mods Metallica88 XMODS 7 02-16-2004 01:16 PM
hey hey hey where is everybody? DaRkKeNHeArT WWS Pro 1 11-19-2003 06:43 AM
As for IRC and http://www.intrepidrc.com/ Scar Dynamite Rocket Racer 4 12-24-2002 12:25 PM
Bitchar-G IRC chat? Smurf Bit Char-G / MicroSizers 1 10-07-2002 08:39 PM
