Old 12-23-2002, 04:34 PM
brandxman brandxman is offline
Angry Cant change ID
Just got a set of 4 in the mail and i woiuld like to reset the ID's so that they all can battle, then all came set on ID 4. I've followed the instructions on the ToyEast web page but have still had no luck.
All of the tanks work just fine, i just cant set the ID's.
Any suggestions????
--B
Old 12-23-2002, 06:19 PM
BillyBonz's Avatar
BillyBonz BillyBonz is offline
I had this problem too. When you press the ID button, you see the tank flash it's belly light, keep holding the ID button until you see the green OK LED on the controller. When I first tried changing ID on my tank, I was releasing the ID button when I would see the tanks flash it's light. There is a few second delay between the tank flashing it's light and the controller's green OK.
Old 12-24-2002, 03:36 AM
Finally got it to work. I guess i wasnt holding the tank close enough for it to recive.
thanks for he reply.
--B
Old 12-24-2002, 09:05 AM
BillyBonz's Avatar
I'm glad you got it figured out. Also its worth a mention, the Ir LED that that sends out the ID signal is located under the controller in a small hole by the charger contacts. Just in case you didn't know. At first I thought it came out of the front of the controller.
Old 12-24-2002, 09:18 AM
Namuna's Avatar
Namuna Namuna is offline
Ahhhh, nice find BillyBonz. I had thought the IR up front controlled the ID as well.
Old 12-24-2002, 11:23 AM
BillyBonz's Avatar
Yep, so did I. That is why on some sites they show pix of changing the ID by setting the tank on the table and putting the controller over the tank. Seems to me they could have saved a few $$ and used the Ir LEDs in the front to do the same job. There prolly is a reason, but I don't know what it is.
Old 12-25-2002, 01:11 AM
Racemonster505's Avatar
Racemonster505 Racemonster505 is offline
Bit Nutz
Send a message via Yahoo to Racemonster505
ok someone go to the company and knock some sense in them and tell them the right way to build these
"Im Not Crazy" Atleast That what the voices in my head tell me!
Fit Racer
Fit Racer
Picture of Freq change ? yoshi Bit Char-G / MicroSizers 2 01-20-2004 09:11 AM
how do u change the remote's frequency mattsx2005 ZipZaps 7 01-14-2004 08:17 PM
Gear change question for special editions doctor dole Bit Char-G / MicroSizers 0 01-03-2003 06:35 AM
[IMG] code is OFF??? How to change? BackInBlack Miscellaneous Discussion 4 10-23-2002 06:33 PM
How can I change my Username? Zakkorn TinyRC.com Shop Support 12 10-12-2002 12:47 PM
