Old 12-17-2002, 05:26 PM
jimerone jimerone is offline
tech question? help please
i have a initial d bit charg.. 1.0... 27mhz
my car is much slower than my freinds 1.0 cars(bit charg)..
also.. my car dramaticly slows down if i am going foward and turning at the same time.. anyone else have this problem?
remedy?
also..
i have a 3X5 oval track.. what is the highest motor i could run without flippin over all the time?
thanks
jim
jimerone@yahoo.com
Old 12-17-2002, 06:53 PM
bill's Avatar
bill bill is offline
I are smart....
If I remember correctly, it's pretty much agreed upon that not all cars are built the same. Some are faster, some are slower. You must be one of the unlucky ones.
As far as the motor questions, that's a little harder to answer. How about buying all the motors and trying it out??
Old 12-17-2002, 07:13 PM
IznastY
That sounds like ur batteries arent that good. my car only does that when the A. Remote battery is bad or B. the car battery is bad. try replacing the remotes AA batteries and if that doesn't work then get a 150 nimh battery for ur bit. hope that helps.
Old 12-18-2002, 12:13 AM
Azimov's Avatar
Azimov Azimov is offline
I process, therefore I am
Yah, sounds like you just need new batteries in your controller/charger. When the juice in the car gets low, you have less power for turning and moving at the same time. The steering coils have a very high internal resistance and draw all the juice from the motor.
Plz Look!! Slipper And Or Tranny Question! lilrichie1306 Micro-T General 3 01-24-2008 02:22 AM
smart range question rydzjunior XMODS Mods and Projects 0 03-03-2007 07:39 PM
Is this normal? (newbie question) WSPFreak ZipZaps SE 12 12-29-2004 12:38 AM
Question, please awnser quickly. Supra-00 Bit Char-G / MicroSizers 17 10-25-2002 11:32 PM
Question about model putty... SPEED Bit Char-G Mods and Projects 1 09-28-2002 10:19 PM
