Old 12-17-2002, 09:59 PM
I2ed I2ed is offline
Send a message via AIM to I2ed
dual batt mod with two 100 mAh nimh battery
how well would these two work in a zipzap? if it does work would i be able to run a 3.2 motor?
Blue Honda ZZ w/ Dual Batt Mod
Old 12-17-2002, 10:23 PM
go_zz_go's Avatar
go_zz_go go_zz_go is offline
more power!!
should work ok as long as you dont fry the batts in the soldering process,,,and yes it should run the 3.2 it did mine
Old 12-19-2002, 09:49 AM
Bunta Bunta is offline
Hi peeps,,
If you do this mod,, I really recommend that you do a Bit PCB swap too,, that way you'll get the most juice to your 3.2 motor. I wasn't too impressed with my 2 cell ZZ, it was faster than original, but not even close to my 2 cell bit. After I switched the PCBs, then my ZZ was just as fast as my Bit. It is still fun to drive without the PCB swap, but it's just more satisfying to drive with the swapped PCB.
I just wanted to share this opinion with ya,, (I know stridex agrees with this opinion too! huh stridex)
-Bunta out
Custom Mods R us
batt mod with two 100 mAh nimh battery I2ed Bit Char-G Mods and Projects 0 12-17-2002 10:18 PM
My ZipZap now runs circles around my Bit! (dual batt success) caver01 ZipZaps 16 11-05-2002 11:22 AM
ZZ Dual Battery Mod Mattydiah ZipZaps 1 10-14-2002 10:58 AM
Can I mix NiMH and NiCd for dual battery mod? Def Bit Char-G Mods and Projects 5 09-30-2002 02:14 PM
