I used these for my TAMIYA cars.... is there anyway to make them work with a BITCHAR charging base?? I can just run the clamps onto the wire of the wiring base...
The 910 is a variable charger and i can set the charging currnet high or low and anything in between.. if i set it to low.. would that work.. it doesn't really say what it does though.. the other one is only meant for 1200-1700mAh and might not work.. whereas the 910 doesn't say anything specific.
I think you would damage the battery, and possibly cook the charger because they are meant to charge batteries that are 7.2-8.4 volts. I use a DuraTrax Piranha Digital (which can charge 1-8 cells). The MRC SuperBrain 959 has a single cell mode also. Both retail for less than $50.
