Old 08-01-2002, 05:55 PM
CivicMachina
New Car Problem
I recently bought the special edition penzoil-zexel skyline (27Mhz) and red rx-7 (57Mhz) and the rx-7 runs consistantly with no problems (except slower than the gt-r), but the GT-R has problems all the time, it will stop working for seamingly no reason and then if i charge it...nothing, so then if i take it apart (take out rear axel, gears, heatsink, and motor, and put it back together then it does work again for a while, is this just interfernce because of the frequency or is it something else?
ps-sorry it is so long just tring to be through
Old 08-01-2002, 08:08 PM
kbtoyz902's Avatar
kbtoyz902 kbtoyz902 is offline
Bit OG
Send a message via AIM to kbtoyz902
that happens to most or the newer GTR SE's(special edition). Your going to have to take out that one thing, capcatitator or soemthing. My freinds xanavi wount run anywhere past 4 feet, so i had to unsolder that piece of crap. the link to that tip is: http://mywebpages.comcast.net/qfm/racing/mod_02.htm#06 look at tip #6.
Old 08-01-2002, 08:23 PM
ViperKid's Avatar
ViperKid ViperKid is offline
Redneck Drifter
the pennsoil doesn't have it, so don't waste your time
Old 08-01-2002, 09:57 PM
tinyrc's Avatar
tinyrc tinyrc is offline
CivicMachina, does it feel like a range issue or a power issue? When it dies as you describe, if you move closer does it work again, or does it stop working until you rebuild it? It sounds like your motor may be loose, in which case bending the retension tab slightly to put more pressure on the motor should fix it.
Old 08-01-2002, 11:12 PM
kbtoyz902's Avatar
Bit OG
i thought all the orange controllers with a G on em have those cripplers.
Old 08-01-2002, 11:44 PM
CivicMachina
it's not a range issue because i can set the car on the charger and it won't move, but the steering will still work
Old 08-02-2002, 08:08 AM
ylexot ylexot is offline
Nope. There seems to be no rhyme or reason to it, but the current data pretty much shows that if you have a 27MHz car, it doesn't have one...period. The only 27MHz car to have something was my nephew's NSX-R, but it doesn't seem to have increased the range. Not sure what that cap did. Oh well, it's gone now.
Xanavi Hiroto Skyline GT-R 57MHz
Booster 35MHz
MicroQ Porsche 45MHz
Peugot Bullet 49MHz
Skyline GT-R Bullet 40 MHz
WRC Impreza Nikko iRacer
Subaru Impreza and Toyota Bb Bodies
Old 08-02-2002, 08:43 AM
tinyrc's Avatar
Did you try my other suggestion RE the motor retention tab? I'm pretty certain that this is the problem.
Old 08-02-2002, 11:34 AM
CivicMachina
is there a chance you give a better explaination of this retention tab things is, is it the little tab on the heat sink that holds it down or is it something else i'm missing, sorry about that, also mine didn't have that little cap, i a noob to these micro rcs
thanx
Old 08-02-2002, 12:55 PM
tinyrc's Avatar
CivicMachina, no problem, sorry if I used confusing terms. What I am referring to is the small contact prong that holds the motor from the side and also supplies current. Not the removable motor holder/heat sink. If you are still not clear on what I mean, let me know and I'll take a pic. Thanks!
Old 08-02-2002, 12:59 PM
CivicMachina
you mean that little bitty metal contact or the the thing on the bottom of the car under the motor, could you show me a pic, i'm sorry to be a burdon like this
Old 08-02-2002, 01:52 PM
tinyrc's Avatar
I just nabbed a pic from QFM Racing and annotated it, if it's not clear from this, let me know and I'll take a close-up pic, this is just faster:
Z car transmission problem? rikc Atomic Z-Cars 0 02-21-2005 11:59 AM
Unequal Right and Left Turning Radius Fix backtrack9 XMODS Mods and Projects 20 10-02-2004 01:32 AM
new car, slight problem jamgunner ZipZaps SE 11 08-29-2004 08:44 PM
Intermittent problem. marc_w Bit Char-G / MicroSizers 7 03-07-2003 12:33 PM
Charger Problem snakeman65 Bit Char-G / MicroSizers 10 10-31-2002 03:35 AM
