Old 11-25-2002, 02:20 PM
Colt45101st's Avatar
Colt45101st Colt45101st is offline
Axle Slot Problem
My micro sizer has kinda dissapointed me that you cant take off the axle too many times or it will be impossable to run because slot is so open and axle fall out any 1 else have this problem or know a fix 4 it
KAMAKAZEE!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old 11-25-2002, 02:30 PM
Blue Bit's Avatar
Blue Bit Blue Bit is offline
Toy Collector
I change my axles regularly and never had that problem. Did you put some sort of lubrication on it?
Old 11-25-2002, 03:22 PM
marc515192's Avatar
marc515192 marc515192 is offline
ZipZap Maniac
Send a message via Yahoo to marc515192
look in the zipzap section there are numorous post about this issue.
Bit PCB MOD
It's a sleeper! hehehehe
M/S Nissan Skyline
M/S Honda S2000
Old 11-25-2002, 03:58 PM
J. Gandia J. Gandia is offline
Hello can you tell how I could get my picture on my name.
Thank You!
Old 11-25-2002, 04:11 PM
Blue Bit's Avatar
Toy Collector
hello
in the top of the page on the main forum screen, there s a button called "USER CP"... click that and click on edit options. At the bottom of the screen you'll see "Avatar". You change or add your picture there.
Old 11-25-2002, 04:16 PM
Thank You!
Old 11-26-2002, 01:56 AM
eyebee127 eyebee127 is offline
i used a little bit of elmer's glue. using a toothpick, i made sure it didn't clog the slot. i read that some people used epoxy or crazy glue, but i think elmer's glue is easier to work with. it dries slower, but that just means more control. just my thought.
Old 11-26-2002, 10:15 AM
axle problem
I would install me gear set then I would make small wedges for the slot you could cut them out of small plastic to slip in place.
Good luck it sounds like you stripped your slot.
Repairing a worn rear axle retaining slot rfnagel ZipZaps 5 01-22-2004 01:37 PM
Rear Axle Tip nrmcj Bit Char-G / MicroSizers 8 05-18-2003 01:47 PM
Dogbones popping out? No problem. bluemax_1 Mini-X 3 04-01-2003 10:39 PM
new and improved axle holder fix hogjowlz Bit Char-G / MicroSizers 1 03-04-2003 03:24 PM
Axle problem? blind Bit Char-G / MicroSizers 4 08-18-2002 09:03 PM
