Old 11-28-2002, 07:39 AM
pakiplaya
how do u put your Suspension bar in?
do u just pull it out or have ta open the front?
Old 11-28-2002, 08:54 AM
ClearStorm ClearStorm is offline
Team Mods Member
Send a message via AIM to ClearStorm
If i understand you correctly, u just have to open the PCB cover and go beneath the PCB. If you look toward the front of the car(while under the PCB) there should be a screw that holds the steering stuff. Just unscrew the screw and u have access to the Suspension.
I am doing this mod soon too
Eclipse ZZ w/ Microsizer PCB:
Also: 2.8 DKS Motor, Red Gears
Coming Soon: Civic body with Full BodyKit, Muffler, and Underglow.
Old 11-28-2002, 09:08 AM
ZIZI's Avatar
ZIZI ZIZI is offline
I think he means how to change the little white suspension bar...?
If you want to change that one just use the screwdriver you got with it and pry it out...to put it in just oush it really hard and it will snap in...
(If that is what you were asking?)
ZZ RX-7
No reverse mod, PCB mod
NOS Motor
3.8 (in the mail)
Old 11-28-2002, 10:12 AM
Azimov's Avatar
Azimov Azimov is offline
I process, therefore I am
I pry it out with the little screw driver, while holding my thumb over it so it doesn't fly off into another dimension and disappear. I put the new one in with the front tab in place first, then press it down with my thumb until the back tab snaps in.
Old 11-28-2002, 10:29 AM
marc515192's Avatar
marc515192 marc515192 is offline
ZipZap Maniac
Send a message via Yahoo to marc515192
AZIMOV has the way. Thats how I do it too
Bit PCB MOD
It's a sleeper! hehehehe
M/S Nissan Skyline
M/S Honda S2000
BCG Drift Set: Useful? ownzorzor Tips, Mods and Reviews 0 10-17-2003 03:49 AM
Still confused about spring suspension!? shane45-1911 Bit Char-G Mods and Projects 3 10-26-2002 01:41 AM
Use stabilizer bar with spring suspension? shane45-1911 Bit Char-G Parts and Hop-Ups 3 10-17-2002 09:38 AM
