Old 11-19-2002, 09:54 PM
33mm 33mm is offline
How do I mod the controller after a dual battery mod???
If you have any directions or any links please post!!! Thank you. I know how to do the car just not the controller. Thanks a lot.
Have Auto Modellista set.. Will do dual battery mod!
Old 11-23-2002, 02:27 PM
Chris's Avatar
Chris Chris is offline
Send a message via AIM to Chris
well, to make a stand alone charger, its really easy. Just open up your controller, and find where the wires from your charging station are connected, then just pull off the wires from the circuit board (be careful you don't pull anything else off in the process!). Go to you nearest radio shack and get a battery holder for 2 AAs, 4AAs, or any other number of AA batteries. then just solder the positive wires from your charging station to the positive wires from the battery holder and solder negetive to negative, and thats it! you will not have an LED light to tell you when the car is fully charged, so you'll have to count yourself.
when you've tried everything and you still lose, there is only one answer, NOS
dual cell controller nxnitrous22 Bit Char-G Mods and Projects 3 10-09-2003 01:32 AM
controller mod & solution for poor range natedogg4674 ZipZaps 4 10-13-2002 09:40 PM
Question about the dual battery mod Redfire Bit Char-G Mods and Projects 8 08-30-2002 11:00 AM
