Old 11-11-2002, 10:29 PM
Ghost of Akina's Avatar
Ghost of Akina Ghost of Akina is offline
da da dum da dum da da
where to cut to lighten the chassis
can anyone post pics of where to cut the chassis to lighten it
"Do you want a new Bit Char-G
WELL I DO TOO!!!!!!!!!!"-me
"i'll let you win, on one condition beat me"-me
racing down akina
Old 11-12-2002, 12:33 AM
d00kie's Avatar
d00kie d00kie is offline
It's super useless!
Ehem...thanks MTL for clearing it up.
Ok, well Barry shaved off the front of the PCB box in order to fit ZZ wheels.
Old 11-12-2002, 01:57 AM
NorCalCoug's Avatar
l33t camber wizard :)
Windows and sides. That's what I do.
Old 11-12-2002, 02:06 AM
MTL's Avatar
MTL MTL is offline
www.d1gp.com
Send a message via AIM to MTL
i think he means the actual chassis guys, not the body
well...if you think about it, there arent much "Safe" places to cut the chassis.....you could make large squares in the steering cover...you could make a square on both sides of the chassis...but that means your internals will be exposed, so some tape will fix that...
you could make a new pcb cover out of ...umm..tape
if you use ZZ rims, dont use any hubcaps..it makes it slightly lighter...
Old 11-12-2002, 04:27 AM
GT-ahh GT-ahh is offline
you can cut out the rear section of the main compartment (where the battery goes) in front of the heat sink...
if you dont like my driving, get off the footpath!
Old 11-12-2002, 11:30 AM
tifosi_ms1 tifosi_ms1 is offline
I had pondered cutting some of the spokes out of the rims. Not only would it lighten the chassi but also the drive train. Duno how much performance could be gaines but any loss in weight shoudl equate to more rpm at the wheels. I will be doing it as soon as the clone arrives.
Bit Char G, Blue Skyline GT-R, 2.6 KIT
Microsizer, WRX won microsizers.com
Micro Q, F360 Modena, Working on it
Castrol Supra Body, Mobil Nsx Body
Old 11-12-2002, 02:08 PM
NorCalCoug's Avatar
Well, cutting spokes reduces the reciprocating mass of the wheel. It won't mean MORE rpms, as you can't make RPMs, but it will mean slightly quicker acceleration from a stop since the weight the motor has to spin is less.
Old 11-12-2002, 03:48 PM
Yeah I was just thinking that you would also probably have to cut some of the gear away as well to really lighten the thing prtty much leaving just the outside of the rim and about 3 tiny spokes on it. I am now really wondering what it might do but it'll be a while til the new car arrives.
Old 11-12-2002, 04:07 PM
J. Gandia J. Gandia is offline
lighting up cars
The only real way to lighten up anthing is to reduce the the weigth of the cars. For starters
you could cover the windows of the cars and wet sand down the body the reason I say wet sand it
doesn't scarch the the body. Next the chassis looks pretty heady also a good sanding of the botom of it could prove wonders. try this first
before you mess with the the structure of the cars
remember the car was made for a reason, also
I guess drilling small whole in area's that dont
contribute to the main structure of the cars won't
hurt good luck!
Old 11-12-2002, 10:23 PM
NorCalCoug's Avatar
As it's a reciprocating mass you want weight to be even on all sides. Don't cut it down to 3 spokes. Cut it down to 4. That way you have a single spoke matching a single spoke on either end.
J. Gandia- You can cut out the windows as long as you're careful. Yes, you will reduce the rigidity of the chassis but if you're serious about lightening the car you'll take off weight wherever you can.
Old 11-12-2002, 11:01 PM
so i just use a heated x-acto right
racing down akina
Old 11-12-2002, 11:21 PM
im thinkin of cutting down to 4-spokes,remove the spoiler,cut out some of the side of the chassis, cut a little bit of teh steering compartment cap (where the hooks are, they look to big), i need to shave some putty off (hecka weighs it down and buy new body for racing)
Do you really need the suspension bar thing or stabalizer whatever it is
racing down akina
Old 11-13-2002, 02:42 AM
MTL's Avatar
MTL MTL is offline
www.d1gp.com
unfortunetly, you sorta need somewhat of a suspension, because if you dont, your car makes wide turns, and just sloppy handling overall...
but if you are just taking pics....remove it for show
another thing to lighten the body is, make some hood vents and roof scoops...that what i have done...
ive also added a mesh grille to my skyline..so it actually looks normal..haha
Old 11-13-2002, 10:25 AM
faster cars
I was speaking with a friend yesterday who sell mini racer cars.
He told me that he was able to make his cars go faster by pushing down on the motor. He had a rubber band holding down the motor. The only problem with this was the fact that he had to move the rubber band everytime he wanted to charge up. I though of a better idea you could put a small metal plastic between the motor and the clip that holds down the motor.
Old 11-18-2002, 10:32 PM
darkarchez's Avatar
darkarchez darkarchez is offline
TinyRC - Lancer Racer -
i say take eveything off an jst keep the motor itself
1970 fast & furious charger. need help jdizzy204 XMODS Mods and Projects 14 04-28-2004 03:13 PM
Carbon Fiber Chassis WillS Mini-X 22 08-13-2003 07:17 PM
custom chassis production has started ronak26 Bit Char-G / MicroSizers 45 02-24-2003 03:18 AM
Stock chassis warp Mr Freeze Bit Char-G / MicroSizers 0 12-05-2002 11:35 PM
