Go Back   TinyRC.com > 1/24 and Smaller > Auldey / Radi-Can > Auldey (All)
Old 11-25-2002, 12:50 AM
MTL's Avatar
MTL MTL is offline
www.d1gp.com
Send a message via AIM to MTL
something bad about auldeys that need a fixin
ive noticed that ive taken the skrews that mount the body off the car in and out waaay too many times now, so now the hole where the skrew goes is pretty loose, and the skrews no longer has a hold....
im going to try to add some plastic cement in the hole, and try to see if i can temporarily make it hold when it hardens....if not, ill just have to use 2 rubber band thatll go over and around the chassis.. ;/
sure do miss the "tabs" on Bit cars haha
Old 11-25-2002, 01:20 AM
Mattydiah's Avatar
Mattydiah Mattydiah is offline
Attack of the Ugly Rocket
Well, this is just my silly idea, but maybe you could fill the holes with something plyable like hot glue and then retap the screw in there??
Check out the ZIPFAQ!!
Ok.. I wanna do a wheelie real bad Speedking221 ZipZaps Gallery 9 11-20-2004 03:21 PM
Bitmod motor gone bad!! mcharles13 Bit Char-G / MicroSizers 4 01-09-2003 07:12 PM
Why do Bullets turn so bad??? SPEED Bit Char-G / MicroSizers 4 10-18-2002 06:02 PM
3.2 motor for booster car good or bad?? microsizer02 Bit Char-G / MicroSizers 3 09-12-2002 11:56 PM
