Old 11-13-2002, 02:53 AM
Clint Clint is offline
Wide Open Throttle
Found a good 6v battery
6v 110mA same width as a zip battery but 50% longer. very doable. might even fit under the pcb with a little work.
Old 11-13-2002, 08:29 AM
tinyrc's Avatar
tinyrc tinyrc is offline
Cool, keep us posted!
Old 11-14-2002, 01:18 PM
crutial crutial is offline
its not rechargeable
Its just a regular alkaline battery, you can really recharge it.
Old 11-14-2002, 02:00 PM
Cannibal Cannibal is offline
Where'd you find it?
Old 11-14-2002, 10:06 PM
I mean you CANT really recharge it.
Old 11-15-2002, 06:39 AM
But if you had a convertable zip, it wouldn't be too hard to make something on top of the PCB to be able to snap these in and out as needed. Could get expensive though.
Old 11-19-2002, 01:09 AM
Wide Open Throttle
the battery works fine..i already had my chassis modded for a dual bat under the pcb..so i just plopped this guy in and taped the pcb on top of it..only the pt cruiser body fit...but it hauled a**.
instant acceleration...still would like more current to the motor tho..
(i did jumper a few of the resistors, but the multimeter showed no change to the motor. so that went back to stock)
i then took the battery apart to see what it was made out of and it is just 4 1.5v button cell batteries with a fancy cover. FYI three of these batteries are the exact same size as one zz battery(4.5v).
so you can run about 6 of them under the pcb/mustang body with no problem for a total of 9v@150mA.
with the 6v batt the motor did not get hot.
Old 11-19-2002, 01:14 AM
Wide Open Throttle
oh and i did recharge it a few times directly with an ac adapter at 7.5v...
to a point..
it got pretty warm..but held the charge and was perfectly reuseable.
warning:alkalines get really hot when attempting to recharge..you can easily blow them up.
Car battery charger (not from an actual car but close) NOS man Bit Char-G / MicroSizers 0 08-28-2003 11:13 PM
6 Volt mod test with video-Any ideas? jpaustin Bit Char-G Mods and Projects 9 01-30-2003 02:43 AM
BC-G Battery vs. KIT Battery datamonster Bit Char-G / MicroSizers 1 11-12-2002 05:19 PM
