Old 11-14-2002, 07:30 PM
The Dude The Dude is offline
Send a message via AIM to The Dude
Bad LED bulb?
Finally got the time to throw my Bit Char Light LED kit together. Everything is soldered in place, everything looks good. But only one LED is lighting up! I would assume that means the circuit is good, therefore the bulb must be bad. Could I be wrong?
I have no problem picking up another LED and throwing it on, but from what I've heard you can't pick up LEDs as bright/good as the ones with the kit from Radio Shack or anything.
Old 11-14-2002, 08:46 PM
Zakkorn's Avatar
Zakkorn Zakkorn is offline
Life's a... Bits
Send a message via ICQ to Zakkorn
It would be nicer for you to just check if the LED works.
You can do this pretty easy.
Just put a flat battery between its legs (each leg must touch a different side of the battery) to see if it lights up.
If it not working the the LED is useless.
  • Nissan Gloria 2.6 + LightMod + 120mAH Cell -- Honda S2000 Silver 3.0 -- Nissan Fairlady Z 3.0 -- Toyota Supra Silver 3.0 -- Mach 5 3.8 -- Ultra Patrol 3.0 -- Ultra Cosmo 2.2 -- Auto Modellista 2.2 -- Bir Racer TRAX Green 2.6 -- DigiQ Subaru Impreza -- Ferrari Set -- LXX -- AudiTT SE ZipZaps -- Mazda RX-8 XMen ZipZaps
Old 11-14-2002, 08:54 PM
Think I could do this while it's still all wired up? I did one hell of a solder job on that biatch.
Old 11-14-2002, 10:49 PM
Shiat...the LED is bad. Anyone know a good place to get a nice bright bluish LED?
Old 11-14-2002, 11:50 PM
Acceptable_Risk Acceptable_Risk is offline
Whoah. Let's not be hasty. You do understand that LED's are one way? If you wire them backwards they will not work. I don't know your level of electrical knowledge, but I've seen plenty of people get lucky wiring LED's and get the first three or four the right way and then get confused when the fifth doesn't light.
Old 11-15-2002, 08:47 AM
I'm positive I wired it the right way.
I even tested the battery directly on the LED, still didn't work. I'm emailing Toy East god dammit!!!
Old 11-15-2002, 01:34 PM
Have you tried www.bgmicro.com?
Old 11-15-2002, 01:47 PM
The problem is really trying to find one to match the one with my kit. It's PERFECT...I'd really love to find one or two more of these.
LED switch Turboas ZipZaps 10 05-18-2003 12:50 PM
Unusual LED behavior InGaN Miscellaneous Discussion 0 01-30-2003 07:31 PM
Best Lightest LED MOD! scottyboyfun Bit Char-G / MicroSizers 9 01-07-2003 01:40 PM
My review of the Toyeast LED light kit... The Dude Bit Char-G Mods and Projects 14 11-12-2002 07:16 AM
