Old 11-08-2002, 08:05 PM
BMW325 BMW325 is offline
slot car motor?
i was just down in the basement, looking to see if any Tyco slot car parts would fit on my Skylines, when it dawned on me; why dont i just Frankenstien the whole motor setup in?
i know it could be done (especially on a bus) but im wondering what kind of battery i would need to power such a beast.
Somebody please tell me
is this is a good idea?
could it really be done?
am i just getting excited over nothing?
chassis=Tomy 35 MHz 2-Spd
body=Silver Nissan 350Z
motor=ZZ NX
(Lambo set in the mail)
Old 11-09-2002, 12:44 PM
link 228719's Avatar
link 228719 link 228719 is offline
Genesis soccer!
the other day i was cleanin out my closet and found all my slotcar stuff....and i was just thinking of a way to do that.
so please tell us if it can be done.....
i think it can though
I race bits.....i race mini-zs......
i live for competition.......
Old 11-09-2002, 07:38 PM
r.c.dealer's Avatar
r.c.dealer r.c.dealer is offline
deviant bit char-g pro
The slot car motor is probably as large as the Bit's PCB, and about as thick as the diameter of front wheels of a bit. The motor would also require alot of current and probably around 9 volts to run. I am talking about H.O. scale slot car motors.
So my opinion if its worth anything to you is its an interesting idea, but wouldn't work.
Old 11-10-2002, 01:50 PM
i still think that it could be done on a bus
motor=ZZ NX
Old 11-11-2002, 04:24 AM
alpha1's Avatar
alpha1 alpha1 is offline
Runs with sharp stuff
You can probably use this motor on a scratchbuilt project. If you still have the transformer from the slot car set, see what the voltage output is. It should be around 9 volts.
Old 11-11-2002, 11:02 AM
mbartell mbartell is offline
so I re-wired it
frankenstein
I got a generic $10 bit- thing for the steering spring. It's a little big compared to others, but hey- it's for parts.
It uses two motors- one for steering and one for movement, and I got an idea- make a tank-steer type stomper with 2 motors. I wired it up, and it does have enough power to turn the stomper motors, when run by a test AA battery. I'm thinking that a slot car motor may work, but they usually run on much higher voltage.
Plus, it probably will only give you about 1min run time unless you get some big honking batteries.
I'll try and post something on the stomper, once it's a bit more than a pile o'parts.
Uhh, gee thanks Radio Shack.
Famous last words:
Hold my beer and watch this
Old 11-11-2002, 01:43 PM
john john is offline
Too Many Hobbies
I was wondering about this myself. I posted about it a while ago and someone said that it runs on 12V.
What I would do is cut the front off of the slot car chassis and glue on the front of a ZZ or Bit chassis. So now you have steering and lots of motor.
Fit the PCB and a small battery in there mostly for steering, and wire the steering part. Then wire the motor leads through a 12V battery (possibly with a transistor) to the slot car motor. I don't know how you'd charge it, but for drag racing I think it would just about always win. I also don't know how you'd get everything to fit. Let me know if you pull it off, I'd love to see it. I don't have any slot cars, and I doubt that I'll buy one just to cut apart, so I doubt I'll be trying this one. Good luck!
picked up a black mustang and the new booster motor pack. OMG Clint ZipZaps 6 04-21-2003 09:20 PM
Motor Support Sub-Forum - Read This First! tinyrc TinyRC.com Motor Support 0 03-16-2003 08:38 PM
What gears and motor should I use to get the most power out of my car with a trailer. AudiTF Bit Char-G / MicroSizers 6 11-14-2002 04:38 PM
what motor is in the thunder bolt car riceimport Bit Char-G / MicroSizers 6 06-13-2002 10:27 PM
