Old 11-01-2002, 06:04 PM
Mattydiah's Avatar
Mattydiah Mattydiah is offline
Attack of the Ugly Rocket
Anyone else into 1:1 scale performance?
Since just about everyone here is into scale automotive performance I was wondering how many of you are into real car performance?? I certainly am, I think half the reason I like microrc's so much is the fact that they are like tricking out a super cheap car.
So all you real life performance freaks out there, lets see what you've got!!
I drive an 89 Jeep Wrangler 4.2L. Its bored out almost 100 over (thick water jacket!!), it has a new Hi-Flo carb, a hotter cam, new pistons, rings, rods, valves, the works. New tranny, transfer case, high flow intake and exhaust manifold, cat-back straight pipe and performance computer.
I've never had it dynoed, but if you wind it up and dump the clutch, it can get the front tires off the ground and it will spin the tires into 4th gear, so its got some punch!
Its also lifted 3 inches and is wearing 32's.
The above picture is fresh out of the shop after I had the motor bored out.
Check out the ZIPFAQ!!
I drive an Auldey, because it shouldnt cost you your first born for a 55MPH R/C car.
How to Build a 1/87 Scale RC truck a.k.a.TTTT Overlander TTTT 445 02-25-2004 07:15 PM
Scale Squishy Combat Digi Q 1 11-03-2003 04:22 PM
Combat Digi-Q tank scale? Hecubus Combat Digi Q 4 02-18-2003 01:11 AM
Equation for scale speed and gear ratios. Zephyranthes Bit Char-G / MicroSizers 0 02-10-2003 07:34 PM
Southern California Small Scale Race Breeze Events 0 01-27-2003 12:47 PM
