Old 10-29-2002, 12:24 AM
skyline0276 skyline0276 is offline
help with duel battery Mod
im having trouble with the mod. i went to the Quest for madness site for instructions and mine doesnt work...i did it like they said ...is that site right...is their a store in SoCal that i can go to for help? thanks
Old 10-29-2002, 06:42 PM
delmonk delmonk is offline
Its not that hard, check to see if ur solder is still sticking onto the batteries.
Try soldering wires to the battery contact tabs and each end to a single battery first and see if it runs, then if it runs use an additional wire to solder the second battery to the first, positive to negative.
Also you will need to mod your charger or build a stand alone charge or else you will no be getting a full 3V charge, that could be the problem.
(Racing) Silver Supra with 2.6 engine, (Racing) Yellow FD3S witn 2.6 engine, Red Evo VII with ultimate light kit, (Drag) Blue R34 with 3.8 engine, (Rally) Twin turbo Yellow Toyota bB
Old 10-29-2002, 10:16 PM
i did do the 6v battery charger....
Old 10-30-2002, 03:27 PM
er what is ur problem does the car run or not?
Old 10-30-2002, 05:35 PM
the car doesnt run....it like doesnt get and electricy
Old 10-30-2002, 06:25 PM
Does the car run while still attached to the charger? If not then its the car, if so then its the battery setup.
Finally Got The Courage To MOD... Aerial, Lights, Duel Battery...... :) neo_m Bit Char-G Mods and Projects 4 03-18-2003 03:40 PM
duel battery mod... GoOsEmAn Bit Char-G Mods and Projects 2 12-19-2002 07:00 PM
dual battery mod no speed increase? delmonk Bit Char-G Mods and Projects 7 10-17-2002 12:10 AM
ZZ Dual Battery Mod Mattydiah ZipZaps 1 10-14-2002 10:58 AM
