08-24-2008, 11:59 PM
Dnano bearings
Hello guys,
any idea whats the bearing size for the front wheels?
Thanks.
09-03-2008, 11:06 AM
Tiny. I was wondering, does anybody come around here anymore? I haven't seen any new updates or peoples rides or anything.
11-30-2008, 06:04 AM
1.5x4x1.2mm
tiny means 1.5mm hole, 4mm outside diameter and 1.2mm thick
04-20-2009, 10:31 PM
Just installed 6 bearings purchased from eBay. The car runs quieter. Installing was quite challenging and fun. I dropped one of the springs on the carpet floor and I had to spend about 5 min to look for it.
OK, I don't notice the difference any more... Maybe the runtime will increase..
Either way, this is an awesome car out of the box.
dNano - Corvette (04/10).
04-26-2009, 11:29 PM
After comparing with the other dNano car without BB's I could not believe how badly the metal BB's performed. I took them all out and put the plastic bushings back in and the wheels spin more freely. Don't waste your money on ebay ball bearings.
04-27-2009, 01:54 AM
So they weren't Kyosho brand bearings? My bearings were a huge improvement? Did you try cleaning your bearings in a little denatured alcohol and water, then relubing them? Did you lube them to begin with.
04-27-2009, 02:03 AM
I didn't lube them. Maybe that's why they were worse than plastic bushings. I would give it a full throttle holding the car in my hand and when I let go of the throttle, the wheels came to a stop more quickly than the one without the bearings. I will give them another try with the oil. thanks.
04-27-2009, 04:06 AM
They're almost worthless without some light lube. Anything heavier than bearing oil will bog them down. While you're at it, lube the pinion and spur gear.
08-01-2009, 02:26 PM
i got mine bearings today from kyosho
installing them was a challenge but fun
and wow what a improvement does it make
