Perfex KT-18
No.82001
Ergonomic design contributes to even better performance from the 2.4GHz MINI-Z.
Advanced stylish design matches the performance of high-end transmitters.
As soon as it is switched on, the KT-18 transmitter automatically starts scanning the frequency spectrum for open bands, eliminating the need to check your band or use crystals and allows up to 40 cars to be run at the same time. Combined with the 2.4GHz MINI-Z Racer chassis, the fastest processing speed ever produces incredible response. And it is amazingly easy to use. Simply register the transmitter to the chassis the first time you use it to complete pairing. As pairing is almost a completely automated process, only a few simply steps need to be completed. The ergonomic design provides a comfortable grip with each part exquisitely shaped so fingers wrap around the wheel to realize a more natural driving style. In addition, the energy efficiency of the lightweight and compact design uses only four AAA-size batteries. The lightweight and optimal center of gravity allow for long driving times with minimal strain. Functionality is equal to that of high-end transmitters such as independent setting of throttle end points and left/right steering volumes. With future developments in mind, the KT-18 is also equipped with extended terminals. One KT-18 transmitter can be used with multiple 2.4GHz MINI-Z chassis so if you add machines to your collection, you can use the same transmitter. The ASF 2.4GHz PERFEX KT-18 represents a new generation in radio control systems.
-As soon as power is switched on, the transmitter automatically communicates with the chassis and scans for open frequencies.
-Automatically allows up to 40 cars to be operated safely at the same time.
-Simply perform the pairing process once to register with the chassis and start using.
-A single KT-18 can be paired and used to operate multiple chassis.
-Digital trims allow precision adjustments.
-Operating trims produces audible tone notification.
Required for Operation
Four AAA-size alkaline batteries.
