Hi J
Yes each body Kit has parts to move the engine placement and different H plates. If you look at all the cars you can see different wheel bases. All this detail makes these cars so cool
Hi J
That's really helpful! Thanks a lot. Before I took the dnano plunge, I wanted to make sure I could adjust the wheelbase to the different tracks I drive at. Thanks again.
Hi J
This is not correct. The cars all use the same H-plate. The wheelbase on dNano is adjusted by the rear body mount that comes with each fitting kit. The fitting kit instructions actually refer to wheelbase in the part name.
