12-10-2006, 11:36 PM
drift set up
can you pls post your drift setup...
12-12-2006, 03:45 PM
Bald rear tires, linoleum, 1100MAH AAAs and dumb luck. Occasionally, I can catch it mid-donut and do a sick powerdrift. Usually, it just goes around in some killer donuts that wont stop till you lift off the throttle.
In my garage, X-mods and Mini-Z are not competitors. Both get stuck just as easy, pull the same amount of weight and are equal on fuel. Why be picky?!
12-28-2006, 07:26 AM
drift wheels, carpet, 4wd goes sidways very well.
hopfully getting the stage 2 motors
12-29-2006, 02:53 AM
rwd or awd better for drifts?
67' Pontiac Firebird -> 6 Cell, Bodykit, AWD, RS Bearings, 4.5 Tie Rod With Blue Front Springs And Yellow Rear, Stage 2 Motor With 9/25 Gearing, Modded Light Kit, Drift Tires...
H2 -> 6 Cell, RS Bearings, AWD, Lift, Body
05' Ford Mustang -> Custom Tamiya Paint, Light Kit and thats it cuz it aint a GM... gonna get a 6 cell when my girl learns to solder...
Traxxas T-Maxx .15 -> Aluminum chassis parts... soon to get a custom light kit...
Associated RC10GT -> RPM bulkheads...
12-29-2006, 10:53 AM
Definatly awd is better. RWD is 100 times harder to drift with. If you don't have awd(which your sig says so :d ) get it. Drifting is as easy as turning once you have awd.
My setup.
For awd, I have obviously awd, batts front, rachargeable batts, stock tires, stage two, hardwood.
RWD, stock tires, batts in back, rechargeable batts, bearings, and stage one.
Xmods:
12-30-2006, 03:24 AM
i learned this with the awd vs rwd at work today...
haha... i took both my cars to work today... cuz i was gonna build the six cell there... but ya... its a bit more involved than that... so ya... but my awd firebird can turn in a tight circle like a forklift... and was just fun as heck to drift around with... fwds and bckwds... the CRUSTang was fun... but not as much... they were more powerslides than drifting... but still fun...
01-04-2007, 03:42 PM
awd
drft tires
wood floor
soft suspension rear
hard " front
SCION
4WD
yellow suspension front axle
blue suspension rear axle
drift tires
decals kit
stage 2 motor 9-25
reachargable rs batteries
NSX
rs rechargables
stage two white
body kit
foam tire
CIVIC
rs rechargables
AWD
body kit
metal bearing
stage two red
yellow front/ back suspension
tie rods
