Major update:
Well, it's been a while since I've updated with pics. Wait no longer
I've gotten the body itself to an acceptable state so I've decided to move onto the chassis in the meanwhile.
So it's time to gut it, cuz it's going under the knife
Buzzzzzzzzzzzzzz, buzzzzzzzzzzzzzzzzzz, buzzzzzzzzz
Here's what I'm going for. I've run into a little snag but I know how to over come that. I'll explain the snag in a bit...
Well, the first snag is that I can't keep the PCB flat and still have the rear wheels attached. Because that corner of the PCB is where the ground wire is attached, I can't even trim it so that the gear would be free to move. So I have to slant it like so...
Problem with the slant is that the PCB still 'rests' on the gear which stops it from turning. So I'll have to shim it slightly. I may not have to tho, because when I run the wires under the PCB it may provide the spacer effect I need.
Oh, by the way, to get the PCB tucked in so neatly you have to cut a notch at the bottom of the column that holds the screw for the steering cover, and also remove the walls from the slanted part of the chassis that is behind the front wheels.
Here is a mock-up of what the finished assembly should look like. Is it just me or does this scream 'lipo-mod' to you too?
Here is a side-by-side with a stock bit. This was just to give a height comparison. Notice anything funny about the cell?
Primer anyone?
I think I'll keep the rest of the cards to myself for now. This is one of my contest entries for the Bitpimps competition, so I'll slow down my updates till I unveil the finished ride.
Oh, and I need come Comments & Criticism... need help on the finishing touches, that's always the hardest part.
Maxx
