Go Back   TinyRC.com > 1/64 and Smaller > ZipZaps, ZipZaps SE > ZipZaps Mods and Projects
Old 01-19-2005, 06:01 PM
sporttracguy sporttracguy is offline
Monster motor in a zipzap,, check this out
Well i wasnt sure where to post this,, its half zip zap,, its a fake one made by "Bensin" that i used as a prototype first( i didnt want to wreck a zip zap just yet) but it should be about the same process
I took a zip zap monster motor(yellow because i used the orange in my monster) and removed the little white gear,, then i took the motor out of the "zipzap" and switched the gear heads so it would match on the car. Then i had to take out the dremel and trim a bit.
From there i noticed that instead of just a + terminal on the back side it has both so i had to solder two seperate wires for + and - . from there i used the stock clip and pulled it half way over and go figure,, it still holds it down,, i put a bit of solder on there to tack it in place. then just put it all back together and it has so much torque.. it can climb angles as good as or better than the monster(because of the lower center of gravity) the only limits are the battery life(probably only lasts a few minutes(but then again, this is a fake zipzap and it never really ran very long to begin with)) and the tires and lack of ground clearance,, its still much more fun than it was.. check it out
This is it next to the monster
Old 01-19-2005, 06:02 PM
here you can see the difference between the two motors,, the stock one was tiny
and now just a few views of what i did to make this work,,
Old 01-19-2005, 06:03 PM
this mod probably only took me half an hour,, most of the time was figuring out if it could be done or not lol
Old 01-19-2005, 06:04 PM
ok, last one,, let me know what you think
i know this is a edgy post because its not a real zip zap but i did use a zip zap motor lol,, and i think if anyone is willing to chance wrecking a zip zap its a fun mod
Sporttracguy
Old 01-19-2005, 08:07 PM
damootch's Avatar
damootch damootch is offline
Good work!! Do you think you will try this mod on a ZZ?
Did you notice more speed or just more torque?
-Mootch
Old 01-19-2005, 10:13 PM
I may try it with a zip zap one of these days but we will see, im not yet prepaired to wreck my only zip zap se yet..when i get a few more ill try it out. as far as speed and torque goes, since its not a real zip zap the speed sucked before and it didnt have much of any torque with the little stock motor.. with the new motor it has a ton of torque(can climb anything a zzmt can climb(minus the ground clearance and larger tires) but the climbing angle is just as good if not better(lower center of gravity) speed wise it has a little bit better speed(compaired to stock) but not much,, keep in mind its a torque motor..
I think the only reason i would do this on a zip zap is if i wanted a "rally" style zip zap,, it wont have the ground clearance or the suspension of a monster but it does have the torque
Old 01-20-2005, 01:08 PM
ok, well i got tired of having all this torque and not being able to use it,, i took two small LEGO tires and ground down the inside a bit so they would streatch over the rims.. I had to trim a bit of the frame to get them to fit but now they work great,, sucker climbs over everything,,1000000 times better than it was as a stock clone.
Old 01-20-2005, 01:11 PM
here you can see the great torque,, the climb angle is awsome.. next to modify the body to fit and it should be good to go
Old 01-20-2005, 01:39 PM
ok, just finished grinding out the wheel wells and back window of the body to make it all fit,, turned out quite nice
Old 01-20-2005, 01:43 PM
ok last pics for now, i promise.. also for the record, i didnt paint it,, this was how it came in the box,, im not crazy about the paint work but im not sure it bothers me enough to paint it just yet
Old 01-20-2005, 03:12 PM
Sky Sky is offline
That's tight!! I also have one of the Bensin (sp?) clones. Mine has never worked, only when on the charger....I opened up both the car and transmitter last night. Car looked fine. Transmitter, however, they had soldered in the 27.000 Mhz crystal on the board and put it in the 49.000 Mhz case! LOL, if I could get a 27 MHz transmitter or crystal I could fix it real fast. As of now, I only have my ZZ Monster, which is awesome! Good work
Xmod Customizer
Old 02-21-2005, 02:17 PM
ZipZapin's Avatar
ZipZapin ZipZapin is offline
Let The FurY Out..
Send a message via AIM to ZipZapin Send a message via Yahoo to ZipZapin
Now, if you can only get those rear tires and rims on the front, that will be seriouslu a sweet lookin ride.
ZZ-1-Monster ZZ With Tricell.
ZZ-2-Dual Cell Eclipse.
Plow Attachment coming soon.
Old 03-26-2005, 08:09 AM
Churro Churro is offline
Yea , a Mini Monster truck
Old 03-30-2005, 05:28 PM
I-luv-Goin-Fast I-luv-Goin-Fast is offline
hey for more speed why dont you eliminate the idler gear and move the motor a bit!
I had a zz that had no idler but it did have two motors
The monster truck motor should provide enough torque to move the zz
Also, i was thinking of how sick it would be if you could dual motor it with the mt motor
You should dual cell it and see if it gains alot of speed
Shane
zipzap SE with monster truck motor kabootle ZipZaps SE 2 09-18-2005 06:26 PM
zipzap SE with monster truck motor kabootle ZipZaps SE 0 08-23-2005 08:23 PM
zip zap monster motor in a bit char-g check it out sporttracguy Bit Char-G Mods and Projects 1 03-17-2005 03:34 PM
Zip Zap monster motor in a clone,, check this out! sporttracguy Bit Char-G / MicroSizers 0 01-19-2005 06:10 PM
ZipZap Monster Truck Questions MattPaintballer ZipZaps Monster Truck 4 11-29-2004 05:53 AM
