Old 05-12-2006, 08:03 PM
cprider_205 cprider_205 is offline
Exclamation My BadA** F-150
My lifted F-150 leave some comment if you like it or wat needs to be improved on it thanx
Old 05-20-2006, 08:09 PM
lphlp lphlp is offline
very nice looking body, good paint.
i suggest u use generation 1 rims with the tires on, the work better than the truck rims with the lego tires, the have a smaller ridge. anyways, u should specify what else u have on ur truck, like specs and suspension, because looks gets u only so far. anyways u should try to fix the bump steer, get a body lift, change the spur gear, (second one to pinion) to higher number tooth one, torquier motor, and some long lasting batteries.
oh yeah, also try to get some locking wheel nuts, wayyyy better than the nylon.
u could also break the tires if u leave like that, anyways, the arent that useful like that. u could also shave the ridge off the truck rim.
-Lino
Old 07-23-2006, 01:04 PM
p4tch
wat tires are u running there are they lego balloon tires?
Will perfection 3.8 and 150 mAH NiMH cell work with my zip zap? Please respond ASAP. ibbored ZipZaps 5 09-11-2003 11:25 AM
needed: a few 150 mah batteries Rmc0130 For Sale/Trade 4 08-08-2003 10:22 AM
150 mah recharge rexdale_hacka Bit Char-G Parts and Hop-Ups 3 04-05-2003 12:41 PM
My Battery Died... Yfactor QFM Racing Customer Support 5 02-26-2003 12:12 AM
just got my 150 mah's today Epochracer34 Epoch RC1/43 2 01-16-2003 03:21 PM
