Xmod Xmods Fastest PRO BIG BLOCK V - 12 Stge20 MOTOR * 70K+ Note: ( this will only fit in custom Xmods!!!, recommend 2x2 fets for better flow to the motor. For more power use 6 or 7 cell, if you got the $ go for lithium AAA.) This motor was tested on 6 cells to run 47 mph+.
Xmod Xmods"RedLine 5.7 PRO MOTOR For Evolution Cars Only!!!. Its tested over 65k+ with a 6 cell upgrade. For those who got TWIN TURBO FET UPGRADE the best motor for you is the SUPER MODIFIED REDLINE 5.7 TURBO MOTOR. If you dont have fets your still in luck you should try MODIFIED REDLINE 5.7 TURBO MOTOR. Note: (these v10's have the same amout of power as v12's just smaller in size.)
This Info was from the Speedologist's who made the motors. So i hope this helps you get the most power out of your xmod.
In my words
Stock is for suckers & Speed is the real deal so get out there and smoke the competition.
