I need help with this! You will think im stupid but every time I turn at full speed with my zz se it fips over I think the tires are draging on the ground But inm not sure.and I only have a
21,500 RPM Performance Motor
Stock Tires
12:1 Stock Gering
Might want to play around with tires a bit. Might want to install an old cheating mod (clear styrene) to bottom of chassis. Might want to play around with gear ratios.
If you change the tire compounds Front / Rear you might just notice an impressive change in how much it flips.
