Old 12-17-2005, 08:45 AM
flamehead_16's Avatar
flamehead_16 flamehead_16 is offline
Naruto Champion
Xmod Conversions
does any one know how to get a mini z wheel to and xmod because i all know is it needs a special spacer.
Old 12-17-2005, 05:18 PM
HammerZ's Avatar
HammerZ HammerZ is offline
Thrasher
For most Mini Z wheels you will need an adapter piece to fill the larger bearing hole with. I don't have any links, but have seen some floating around. I think you also need to grind off some on the inside to get the offset right so it would tuck under the body.
The new AWD Mini Z wheels use a double flat shaft, not a single flat like the Xmods have. Other than that the Mini Z AWD wheels would fit if you mod the shafts with a file for it to slide on.
Old 12-18-2005, 06:51 AM
Naruto Champion
who makes them and when you find a link could you post it
My Xmod is completely F***** bengali548 XMODS 3 07-06-2006 11:19 AM
Biggest Fastest REDLINE "BIG BLOCK V-12" ProPulsion Dragster XMOD MOTOR Ever! MicroRCracer XMODS Mods and Projects 25 01-26-2004 03:42 PM
Xmod Corvette Project Racer240 XMODS Mods and Projects 6 12-02-2003 08:57 AM
