10-02-2005, 09:31 AM
Check out this Terrain!
this is crazy... but very cool...all made from stacks of sheet foam
10-02-2005, 02:27 PM
Terrain
Great job!
What did you use for the finish? Paint?
10-03-2005, 10:13 AM
Wish it was me... I found that pic on a German Bit/TTTT forum
www.bit-racer.de
10-03-2005, 08:00 PM
The finish is made with
gypsum, mortal, cement, tile adhesive
bable fish doesn't help everytime
I don't know the correct word. Something to repair walls in your house. Something that is like powder and you have to mix with water.
Use a spray bottle with water and moisten the surface at little bit. Add some color concentrate to the water for a better finish. You can get it at your local hardware store.
Then put some powder on the wet surface. You will get best results, if you use a sieve (german "Sieb"). Let it dry/harden and repeat the whole procedure several times.
That's it.
diets - wish it was mine
10-03-2005, 09:08 PM
diets - wish it was mine [/b]
Plaster....or maybe spackle
10-04-2005, 01:59 AM
Go Banana!
I was at The Train Shack in Burbank today and found some really nice Woodland Scenics silicone rock molds. Picked up like 10 different ones along with some plaster and foam blocks. I'm waiting on the rest of the truck components but my MAN 5t is 50% done now. Then I'll measure the steering radius so the terrain can be custom made. Then I'll clear out some space in the garage so we can have a spot to drive.
Can't wait for our first SoCal TTTT Competition!!!
10-04-2005, 03:30 PM
My first Man 5T is 90% finished... I'm stil waiting for a speed controller from Germany (R500).and I have to figure out my steering linkage...and I'm done...check it out
10-04-2005, 03:31 PM
another
10-04-2005, 04:12 PM
Nice work!
Now you need a TTTT modul
I only miss a pic from the bottom!
diets - ist immer ziemlich neugierig
10-04-2005, 06:57 PM
Here's the bottom... I just need to make it neater and maybe paint it... but the steering works.and that's the important part
still waiting for my ER500 Speedcontroller from mikroantriebe.de
(which seems like it's taking forever)
I want to possibly make a brass chassis for my next one
10-04-2005, 07:28 PM
post some pics of what you have done so far...
10-04-2005, 11:46 PM
Go Banana!
10-05-2005, 07:26 PM
Cool crane!!...
If you look at my earlier pics I was going to put the receiver in the cab (it fits perfectly...I just wish they made GWS surface receivers with JST connectors..it would fit better)
but i ended up putting the receiver in the rear by the tailgate.. and I might add lead weights in the cab to balance it out.. it will grip better while crawling if it's heavier so I'd rather add weight than shift it..
looking good so far Nate... what are you going to do about the steering/front axle? and the 4WD?
BTW.. I have the same computer tower... LOL
10-05-2005, 07:38 PM
BTW.. I'm also considering mounting the servo in the cab like this on my next one:
It's should make the steering linkage simpler...
10-05-2005, 07:40 PM
...or in the center..behind the cab...like this:
