Old 08-16-2005, 10:51 PM
mullermw mullermw is offline
Batteries
I need to replace the batteries in my Combat Digi-Qs. From what I've been able to find, the batteries are 1/4 AAA 80mAh NiMh 1.2v cells 10mm x 10mm.
I saw some at batterieswholesale.com but the specs were a little different at 150mAh 14mm x 10mm. I'm not sure if 150mAh is compatible with the charger and they're too long (if the dimensions are correct).
I've also seen battery packs of 80mH 1/4 AAA cells for RC Planes. I'm thinking I could break up the cells for my CombatQ.
Has anyone here successfully replaced batteries? Where did you buy them?
Old 08-26-2005, 08:25 AM
Alard Alard is offline
Have extra cells
Send me an email for info.
Old 08-26-2005, 10:56 AM
Thanks for the reply.
I already bought a 1/4 AAA batterypack from here:
http://www.servohut.com/A%20kan_nimh_batteries.htm
This one has 8 cells, enough for 4 battery replacements:
KAN Ni-MH 9.6V Battery 1/4 AAA 80 mAh Eight Cell Flat P $8.50
Since the cells were already soldered together, I removed two cells from the pack, keeping them soldered together. I removed the leads from the old batteries and soldered them to the new batteries. I'm lousy with a soldering iron and I had some difficulty getting the solder to stick to the battery but I got it eventually. Tanks are good as new.
I think next time, I'll see if I can rig up some kind of solder-free connectors so that battery replacement can be done without soldering. Anyone have any good ideas for that?
Tired of waiting for your batteries to recharge... tavisjohn XMODS Parts and Hop-Ups 3 12-08-2003 06:06 PM
Cheap Batteries! Heat Bit Char-G Parts and Hop-Ups 0 02-02-2003 10:36 AM
