Old 03-27-2005, 07:27 PM
broke ess supra broke ess supra is offline
What's your favorite battery setup?
I started this thread because i wanted to hear other's opinions on the pros and cons of different battery setups.
Personally i have used 4,5,6,7, and 8 cell battery setups. I haven't tried lithium ions yet so some input would definately be appreciated.
ok this is what i think(using tight turns,AWD,soft slicks,Medium suspension all around, s/b magnets, ball-bearing can, ~37k motor)
-4 cells is good when it comes to a smooth surface in handling, on pavement it is incredibly unstable. top speed and accell are bad
-5 cell with battery behind back bumper is faster and the handling might be a little worse
-6 cell with batteries behind back bumper-accellaration is best with torque and so is top speed. Handling is shoddy, front end really loosens with increased top speed and flips over sometimes.
-7 cell has so much torque that the car can't really put it to the ground, top speed i believe suffers a bit and handling is suprisingly pleasent. the added weight really added some stability on concrete. The car when on full throttle and turn will sometimes drift a bit into a turn not lossing a lot of speed when taking high speed turns.
-8 cell handling is a little bit like 7 cell setup but more drifty in fact tires can't put down the torque to the ground. too much tire spin on turns. I really didn't take the time to change the setup to make the handling better but i believe its just too heavy. CHECK THIS OUT so much darn torque that it ripped my crazy glued tires right off the rims! But i see hardly any top speed and accell is terrible.
In conclusion-6 cell for accel and top speed and 7 cell for handling
Old 03-31-2005, 10:41 PM
rssjib rssjib is offline
Too many XMODS
Dude - the Li-Ions rock...think of the weight savings alone.
And, where the hell did you fit all of those batteries?????
The Li-Ions do have good power and are hard to describe until you run them...they absolutely kick azz...
RSSJIB
(2) Yellow Skyline GT-R: AWD, AtomicMods 180S motor, Li-Ion, CF driveshaft, suspension, bearings
(2) Black Skyline GT-R: AWD, Stage2 motor, Li-Ion, suspension, bearings
'04 Mustang: AWD, AtomicMods SS130 motor, Li-Ion, suspension, bearings
C5 Corvette: AtomicMods SS130 motor, Li-Ion, suspension, bearings
C5 Corvette: stocker
(3) STi WRX: AWD, CF chassis, AtomicMods SS130, bearings, body kit, Li-Ions coming
Black RSX: AWD, Stage2 motor, suspension, bearings
Silver RSX: stocker
Red Supra: AWD, Stage2 motor, suspension, bearings
Silver Supra: body kit, Li-Ions soon
(2) 350Z: body kit, Li-Ions soon
NSX: body kit, Li-Ions soon
'65 Mustang: body kit, Li-Ions soon
_________________________
"rehab is for quitters"
Old 04-01-2005, 11:13 PM
gorbasho gorbasho is offline
seriously. where did u find room to cram 4 more cells in?
Yellow Skyline: S2 9-tooth motor, AWD, hard springs front, medium springs rear, custom graphics, CF drive shaft, CF front and rear upper decks, transparent chassis, wheel shims, white airbrushed rims (stock ones). SOON: black paint
Old 04-01-2005, 11:54 PM
Too many XMODS
If he had 8 cells, he didn't have a body on it...it was just for the hell of it...
RSSJIB
Silver RSX: stocker
Old 04-02-2005, 11:41 AM
fit extra cells
rssjib i did have the body and
-first off i had the roomiest body the toyota supra
-I used two-2 cell packs from a junk xmod that i had laying around
-I mounted one pack behind the back bumper and another right on top of the chassis under the body(velcro helps, no heat sink guys).
-i used one of those yellow bushings to raise the body a few mms on the back body clip
tada-8 cell...oh i also had fets so the motor I was using wouldn't burn da stock ones
i ditched that setup though...like i said before it is too heavy and too much torque for the grip of the tires
I also eventually zapped the antenna with the mess of wires and when i took out the pcb some of the leads were like burnt and hanging off of the board i guess from the increased votage...the funny thing is that everything worked on the board! even with little burnt pieces hanging off.
Old 04-02-2005, 04:23 PM
whats the most number of cells you can run with stock FETs?
Old 04-02-2005, 04:56 PM
-In general i wouldn't recommend sticking 7-8 cells to your xmod because the fets might not burn with a low current draw motor but the board might fry because of the high voltage...my xmod board didn't fry enough to stop operation but i guess it depends on your luck of the quality of the board you get.
-To answer your question It really depends on the motor...a stage 1 doesn't draw much current so 7-8 cells would probably run good...a stage 2 would run 6 cells safely...with four cells i run a 40T armature with spinbrush mags and bb can on stock fets
-the stock fets can handle somewhere in the vicinity of 2.5-3 amps i think...with ohms law you can find out how much current a motor draws if you have the resitance and voltage...so if you have a custom motor be careful...i wouldn't run a hybrid motor on 6 cells for more than 5 minutes and wouldn't even run it with 7-8 cells just to be safe.
Old 04-02-2005, 05:12 PM
look!
Old 04-03-2005, 03:27 PM
man do i wish i had the money to buy a lithium ion upgrade...till then i'll stick to my cost efficient six cell...oh well
Increase short battery life! underglow ZipZaps SE 1 09-17-2005 06:51 PM
Favorite Tire Setup DragonUnit45 Bit Char-G / MicroSizers 1 11-28-2004 06:31 AM
Battery Runtime Tests Namuna Bit Char-G / MicroSizers 25 09-20-2003 09:35 AM
