Old 01-17-2005, 08:03 PM
st33ze st33ze is offline
Problems.
Recently (last night) I picked up a suspention/steering kit from rs. I installyed new springs, tried it out, and my car drove even better.
30 minutes later, i decided to install a new tie rod (4.0 degrees).
After I installed it, my car goes half the speed with the body on, and the same speed with out it...Also, it seems as though my stock differential is making a whole bunch of noise....
Another problem. My car only reverses half the time, and the motions of accelerating, and reversing are very choppy.
PS: Suspention/steering is the only upgrade I have.
PPS: I also took the batteries, and antenna of while I was doing the upgrades.
HELP ME!
-newb
No seriously..Im another xmod newb.
Old 01-17-2005, 08:43 PM
Oh, one more thing. Eventualy, my car does get up to 3/4 of the origional speed...It just takes a reaaly long time. My acceleration is poorer that dirt also.
Thanks.
Common guys! Gimme some help!
-newb
Old 01-17-2005, 09:37 PM
rob3662 rob3662 is offline
the only two things i can think of that would cause your problem is that your front tires are on too tight or where you have your 4.5 tie rod in and now AWD then there is more friction then when the stock tie rod is in. Maybe you should try putting the stock tie rod back in and see if you still have the problem, or you could try installing and AWD kit, and they are on sale at radioshack now for 15.99.
Old 01-17-2005, 09:41 PM
RacinSkillZ101's Avatar
RacinSkillZ101 RacinSkillZ101 is offline
Banned
Send a message via AIM to RacinSkillZ101 Send a message via Yahoo to RacinSkillZ101
also make sure the wheels aint touching the body, and that there isnt binding (possible cause of noise)
also thanks for telling us your a newb, i beleive u got lucky today because most people would have told u use the search button
-note: im not most people and am happy to help as long as the prob isnt too obvious. i.e: "hey i ran my xmod through a puddle to make a splash but now it dont wrk, crappy rs product i knew i shoulda bought a miniZ the extra 100bux means its beter" although there funny, they get old.. but gl with ur car
--note: im not a fan of miniZs and if u dont like it just email me, no need to waste forum space
Old 01-17-2005, 11:45 PM
I have a beach ball...
Ah, you just lucked out, because I am here.
My One suggestion is that you make sure your batteries are fresh before you go tearing it apart because it's moving slowly. ALWAYS check this first if it suddenly starts slowing down, because 99.999999999% of the time, this is the cause.
'65 Ford Mustang
All the RS goodies
Becoming a donor car for:
'04 Ford Mustang Cobra
Old 01-18-2005, 12:43 PM
ChenPokoMasteR's Avatar
ChenPokoMasteR ChenPokoMasteR is offline
A Winner Is You
Send a message via AIM to ChenPokoMasteR
heres the rule of thumb
NEVER USE ALKALINE BATTERIES, use the rayovac IC3's or the radio shack batteries
Make sure that everythings in place, all the screws are in
if worst goes to worst, bring it back to RS
350Z- Cf Drive shaft, Custom motor ( 40T, bbcan, Neo mags), Cf drive shaft, Awd, bearings
Skyline- Cf Drive shaft, stacked fets, 2 cell lithium, AWD, Bearings, Custom motor
Old 01-18-2005, 09:43 PM
Thanks guys....I found the problem.
Its my differential... The noise has stopped now, so has the non-reversing.
My car is back to normal.
Btw...Whats wrong with alkaline batteries? I know NiMH are better....
Does it matter which rechargables I use?
PS: Im getting an all wheel drive kit soon, so that should help alot with the differential.
-newb
Old 01-19-2005, 06:42 PM
Zero-Man
Rayovac IC3's, 15 minute recharge, cheaper than the shack version
Steering problems because of pcb Zephyranthes ZipZaps 16 05-03-2003 12:06 PM
Problems with R-Specs... Vyrus bitchar-gmotors Customer Support 6 02-27-2003 02:02 PM
Problems with UK customs? GSXRMovistar Bit Char-G / MicroSizers 6 10-23-2002 03:35 PM
Steering problems Go0ty ZipZaps 1 10-08-2002 07:20 PM
