Old 01-07-2005, 08:42 PM
mastersmite mastersmite is offline
May the force be with you
Send a message via AIM to mastersmite Send a message via Yahoo to mastersmite
Wtf?!?!?!!
I just got the bearings from RS and one of them won't fit over the plastic at the end or the long rear axle. This ticks me off cuz i have 2 use the bushings on that part of the axle on both sides or it will spin all over the place.
Moege die Macht bei dir sein
Yellow 2004 NSX
Stage 2 Blue 11tooth SB hybrid
blue springs in back, yellow in fornt
AWD
Ball DIfferential
Duct-tape Autobra
Old 01-07-2005, 11:36 PM
HammerZ's Avatar
HammerZ HammerZ is offline
Thrasher
I had that happen just the other day. Only I was using this shop's bearings and it was my front U-shaft, but it broke as I was sliding the bearing onto it. The other shaft fit fine, I think some parts that plastic end is thicker than others. I do not think the cause was the bearings themselves, because the same bearing fit the other shaft fine.
Old 01-08-2005, 11:37 AM
rs2000's Avatar
rs2000 rs2000 is offline
Xmodder
Send a message via AIM to rs2000 Send a message via Yahoo to rs2000
Hmm, how often does this happen? If its a problem that comes around often, i might stray away from getting bearings, or can you dremel the shaft down to make it fit?
*Nissan 350z*
[COLOR=royal blue]
-IC-3 800 mAH bats - 4 cell
-AWD
-Locked rear diff for drift action!
[/color]
Old 01-08-2005, 12:13 PM
I have a beach ball...
I've put bearings in four different cars now, and have not had this problem. It's definitely not the bearing's fault, it's more likely the cars themselves are a bit anomolous.
'65 Ford Mustang
All the RS goodies
Becoming a donor car for:
'04 Ford Mustang Cobra
Old 01-09-2005, 09:53 AM
i think i got it
the bearings hang up on the transition between the metal axle and the plasic cup thing. i think sanding the edge down will get it on the rest of the way.
Yellow 2004 NSX
AWD
Ball DIfferential
Duct-tape Autobra
Old 01-09-2005, 02:52 PM
jamgunner jamgunner is offline
Wannabe TinyRC Pro
Send a message via AIM to jamgunner
i had a similar problem happen... twice. first set had ttroubles going on like you said. the second set had 2 bearings that were falling apart (the inside ring was pushed out). needless to say i got my money back and left it at that.
Old 01-09-2005, 05:08 PM
They were Radio Shack bearings, weren't they? I tell everyone those are junk, and no one listens to me.
'65 Ford Mustang
All the RS goodies
Old 01-18-2005, 10:57 PM
djp42588 djp42588 is offline
Send a message via AIM to djp42588
yea they truly are my car with the rs ones makes a metaly sound, but the other one with aftermarket bearings sounds smooth... plus they were much cheaper! also the bearings are a tighter fit the less time you keep your bushings in so if you run the bushings for awileyou might be able to fit them later
Red Supra = all traction
stg. 2 red motor
suspension, both wheel (im running ones painted white) tire, and body upgrades
speed kills: live long and drive a civic
1967 Camaro = all torque... no traction
md. rear springs and soft fronts side dual exhausts, all go no show and enough power to smoke your civic
WTF?!? brand new car not working Driftwood Atomic Z-Cars 2 07-29-2004 01:45 AM
ZZSE + Perfection King 4.2 == WTF? ax0n ZipZaps SE 4 11-13-2003 12:03 PM
the one the only tightest car ever THE CIVIC anthonyb45 ZipZaps 64 12-07-2002 01:50 AM
Jcpenny R/c Wtf? Colt45101st Bit Char-G / MicroSizers 6 12-02-2002 12:25 PM
WTF 27mhz oem controller controls my 35mhz Bit?? Mellow Yellow Bit Char-G / MicroSizers 1 09-04-2002 09:42 PM
