07-12-2006, 11:27 AM
new drift parts
wut is the first thing i should by for drifting with my stock g35. i was thinkin the drift tires or all weel drive. any thing will help. even do it yourself mods.
07-12-2006, 09:28 PM
ok well ur new to the forum, but next time use the search or just scroll down. drifting rwd is very hard and u will not be able to get long sideways drifts with it. on a nice hardwood floor or cement u should be able to drift nicely so get the awd first. drift package will help but u could just get the tire upgrade and use the hard slicks.
07-13-2006, 10:01 AM
Thnx for the help do u sugest getting a motor upgrade so i can spin the tires more.
07-13-2006, 12:21 PM
this is up to u, you'd have to try it out and see which one u like better. here are some facts tho, the stock setup has the most torque so it's the best for breaking loose ur wheels and keep them traction less. with the stage 2 u loose alot of torque but u gain more speed. if u go with stage 2, use the gears with the most torque.
01-20-2007, 07:37 PM
silentracer, i agree with everything that you say except te fact that you said to use the 100 percent torque motor? I tried that and my xmod goes appx 7 mph. Very Slow i have been drifting for a while( look at my sig  ) and i chose the stage two set at 9 25
SCION
4WD
yellow suspension front axle
blue suspension rear axle
drift tires
decals kit
stage 2 motor 9-25
reachargable rs batteries
NSX
rs rechargables
stage two white
body kit
foam tire
CIVIC
rs rechargables
AWD
body kit
metal bearing
stage two red
yellow front/ back suspension
tie rods
